Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
Offset Cylinder Construction
Old Mar 26, 2007 | 06:51 PM
Maj Easy's Avatar
Default Offset Cylinder Construction
i wonder if the R&D department of cummins has looked into offset cylinder construction????
http://www.insightcentral.net/encycl.../enoffset.html
The engine block has a unique, offset cylinder design in which the bore center is offset 14mm from the crank center. Maximum combustion pressure occurs at a point where the connecting rod is straight up and down in the cylinder. In this position there is zero lateral force so friction and piston slap are reduced.
As a result of the offset construction, the combustion pressure is used more efficiently since the rod is near it maximum leverage point with the crankshaft.
http://www.greencarcongress.com/2007....html#comments
Old Mar 26, 2007 | 07:41 PM
B KIRK's Avatar
Just by looking at the diagram, the rod would still be moving upward during peak combustion with the 14mm offset.
Would also have to travel more distance to reach TDC of the crankshaft.
Plus the offset would mean a smaller rod to clear the bore for the length of stroke.
Don't see any advantage to it.
Brad
Old Mar 26, 2007 | 07:51 PM
bway1341's Avatar
To much for my little brain to compute
Tlutz
Diesel Engine Conversions
Sep 29, 2015 06:05 PM
Kennyw250
Jan 14, 2015 07:47 PM
Oct 31, 2014 08:10 AM
91 7three
Oct 15, 2014 12:57 PM
Oct 13, 2014 08:10 AM
