My 06 Trailer Plug (No LT or RT But I Got Tail Lamps)
Old Mar 12, 2011 | 06:15 PM
wildbill's Avatar
Default My 06 Trailer Plug (No LT or RT But I Got Tail Lamps)
I called Lithia in Billings, MT and they said I need a new BCM (Body Control Module). $1100 installed, but I can't believe that. What happened was the cord for the trailer lights drug on the ground, and it shorted out. Why the frick there isn't a breaker.
Anyway, am I looking at a new BCM, or is there a fuse somewhere that can be replaced somewhere other than the PCM.
Old Mar 12, 2011 | 06:37 PM
Red_Rattler's Avatar
High Tech Redneck
I find that highly suspect... If it was the BCM more then just the turn signals would be fubar. They work on the truck still right?
Old Mar 12, 2011 | 07:14 PM
wildbill's Avatar
Still work on the truck.
Old Mar 13, 2011 | 01:04 PM
MRaynor's Avatar
IIRC, there was something in the 06 where you only got three chances to have a short on the trailer connection and it popped something in the fuse box that would have to be replaced. I don't think it was the BCM, but it was a pretty costly part. And yes everything on the truck would still work. I'll do some digging for ya.
Old Mar 14, 2011 | 11:03 AM
steved's Avatar
Isn't it the TIPM that faults in the 06, and simply needs reset (and reflashed for higher amperage) by the dealer??? Its the fuse box under the hood that gets replaced. I believe MRaynor is correct, that you only get three tries before it needs replaced; but the dealership should know this.
The trailer plug is isolated from the truck's wiring...one should not affect the other.
Old Mar 23, 2011 | 04:33 PM
07redsled's Avatar
my 04 has seprate fuses for the left and right trailer turns
Old Mar 23, 2011 | 04:36 PM
wildbill's Avatar
I got two fuses, RT and LT. No trailer fuses I could find.
Old Mar 23, 2011 | 04:43 PM
steved's Avatar
04 doesn't equal 06...different animals.
Old Mar 23, 2011 | 09:02 PM
wildbill's Avatar
I couldn't find a "Body Control Module" in my repair manual. All things electrical (besides engine controls) run through the TIPM (Total Integrated Power Module).
Old Mar 23, 2011 | 09:08 PM
1st_gen_puller's Avatar
not to be an *** but have u put a test light on your prongs to see if u have power to the turn lamp prong...
