WHat next???
Old Mar 10, 2011 | 09:15 PM
97powerstroke4X4's Avatar
Default WHat next???
I have a 1997 Ford F-250 Ext Cab Long Wheel base. It has a K&N aftermarket air filter and a stock straight pipe. What should I do next? If anyone has a cheaper chip that they wann sell let me know.
Old Mar 10, 2011 | 09:30 PM
95powersmoker's Avatar
Is that K&N a drop in style filter? Those have been known to not seal correctly and let dirt by them taking out the compressor wheel...Might want to think about a Napa 6637 air filter, it does a much better job filtering...
Gauges would be next, then a chip...
Old Mar 10, 2011 | 09:40 PM
joebob3093's Avatar
Moderator
a diffrent intake and a chip would be a good start.
Old Mar 11, 2011 | 08:52 AM
i have a trans temp guage and boost guage. my K&N air filter doesnt have a box. should i get one? does anyone have a chip they wanna sell kinda cheap? or have suggestion of one i should get?
Old Mar 11, 2011 | 09:26 AM
Oh I gotcha, Its an open filter style. That's much better than the drop in style...
I would get an EGT gauge...
Even if you buy a used chip, you most likely will need a reburn... I'll keep my eyes peeled for a cheap TS style chip..
Old Mar 11, 2011 | 10:00 PM
Alright. I am little new to this, but i have been aroud diesels all my life just never tuned them alot. What does an EGT measur? Where would i install it? WHat is a reburn?
Old Mar 11, 2011 | 10:05 PM
EGT is Exhaust Gas Temperature... Very important thing to monitor. You would install the probe by drilling and tapping the drivers side exhaust manifold.
A reburn on a chip is getting the chip tuned for your truck. If you buy a used chip from a truck that doesn't have the same PCM code as you, you will need a reburn for it to work in your truck...
Old Mar 11, 2011 | 10:08 PM
OK. What do you put in the exhaust manifold. Do they sale a kit for EGT? What should the temperature be around? How do you do a reburn?
Old Mar 11, 2011 | 10:10 PM
Yes sir, when you buy the gauge, it should come with the probe and wiring...
Temps should be around 400-600* when cruising and no higher than 1250*
For a reburn, you would have to send it off to a custom tuner and pay a reburn fee...
Old Mar 11, 2011 | 10:16 PM
About how much is both of them?
