Help.....Code po216???
Old Mar 6, 2011 | 03:27 PM
clyoung12's Avatar
Default Help.....Code po216???
What do I need to do to fix this???? Do I need to get a new ip or is there another way to fix this????
Old Mar 6, 2011 | 03:40 PM
deck60's Avatar
here is a quote from dodge diesel forum
P0216 is the VP44 first death cry's.
if you want to slam down the money for a new pump it's up to you, I personaly would walk away since the lift pump is probably toast as well and that is what killed the VP44.
even Cummins has stated the VP44 was a weak pump. if the lift pump died or starts to die and deprives the VP44 of diesel it will fry. I'm willing to say you also had a P0253 code as well (Fuel injection pump fuel valve open circut). this code usualy pops up before the P0216. the VE, P7100, and the new CP3 pumps are considerably more robust when it comes to lift pump problems. the CP3 is the only pump that can actualy draw its own fuel, but lives a better life under positive fuel pressure from the lift pump.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
