94 f350
Old Mar 6, 2011 | 01:46 PM
ktm43's Avatar
Question 94 f350
hard starting my 7.3 its like their is no fuel going to injection pump or filter change pump out still no fuel any one know something
Old Mar 7, 2011 | 05:28 PM
stackboy6.9's Avatar
have you changed your lift pump
Old Mar 7, 2011 | 05:47 PM
ktm43's Avatar
Beer
yes that was the first thing we did didnt help its just getting fuel
Old Mar 7, 2011 | 09:51 PM
DieselCrawler's Avatar
not getting fuel outa the lift pump? how full are the tanks?
Old Mar 13, 2011 | 10:48 AM
Sycostang67's Avatar
Is it hard to start all the time or only when the motor is cold? Have you checked the retrun lines for leakage?
Old Mar 13, 2011 | 12:34 PM
ktm43's Avatar
Question hard starting
yes return lines are good did have a leak on back of engine going across to other bank it seems to lose its prime some way and stops pulling fuel up to the filter assembly i know its got to be something very simple but one of those problems that can drive you nuts
Old Mar 14, 2011 | 08:06 AM
Check the fuel line that runs underneath the motor on the crossmember, they have been know to rub through and leak.
Old Mar 16, 2011 | 11:35 AM
wreckinball's Avatar
Could be something stuck in the pick-up tube in the tank. So just clarify, you replaced the lift pump and arent getting fuel to the filter? If you are getting fuel to the filter, then check to make sure the fuel solenoid in the IP is getting power. Its the spade connection closest to the radiator on top of the IP. Also did you top off the fuel filter when you reinstalled it. If not then it isnt going to prime well.
Old Mar 17, 2011 | 06:54 AM
ktm43's Avatar
Smile hard starting
hi thanks for the reply but after taking to another garage they found that the new fuel pump was bad !!! what is it with these autoparts mgf **** parts thanks again
Old Mar 21, 2011 | 08:38 AM
If the pump was not installed properly, it can be ruined right off the bat. Not saying thats what happened but they need to be put in when the cam is just right. The bent long arm ones at least.
