Injector sleeves or cups
Old Mar 6, 2011 | 01:16 PM
jeeperjohn's Avatar
Default Injector sleeves or cups
I was just wondering how important it was to pull and reseal the sleeves when the injectors are getting replaced. I have read pros and cons. Thanks in advance
2003 - 3500 dually LB7 No mods except for banks 4 inch exhaust and banks brake.
Old Mar 7, 2011 | 07:40 PM
unclecowboy's Avatar
well i will leave a post when im done with mine im not re sealing mine as they are not coming out when i replace my nozzels ill let you know how it turns out if that helps
Old Mar 7, 2011 | 07:48 PM
jeeperjohn's Avatar
Thanks
I am going to be doing mine next week and I am worried about leaks since this will be the 2nd time they have been changed. The first time was by a dealer and I don't think he resealed them. I am not even sure he replaced them all like he said since three more are bad less than 40 thousand miles latter.
Old Mar 7, 2011 | 09:28 PM
wow thats rough well if you find any thing thats useful id be glad to hear from you im a day or two from getting mine done and keepin my fingers crossed i hope it works riht this is the first set ive done kinda goin in blind
Old Mar 8, 2011 | 11:21 PM
veggimaxny's Avatar
I did mine in Jan. every one of my cups came out and i'm glad they did because i know they were seated back properly. Everything i read b4 i did it said if they don't come up with the injector then don't worry about them. I don't like doing thing half way and wonder if it's right so if i did it again i would pull any that didn't come out. reseating them really isn't bad I used red locktite sealant like everyone says you should get the cups in straight and with a drift or even an extension for your ratchet will do. drive it in gently till the drift bounces back with each smack you'll know it's seated. don't forget to clean the seat areas spotless b4 you reseat them
Old Mar 9, 2011 | 08:19 AM
jeeperjohn's Avatar
thanks for the reply veggimaxny. I agree that it would be better to reseal all the cups. My problem is what if some of the cups do not come out with the injectors? Is there some other way to get them out with out the tool that no body seems to have. Plus it is pretty expensive. Anyway I was going to buy one but the manufacturer is not even going to have any till late april or march. Too late for me.
Old Mar 9, 2011 | 08:00 PM
thanks for the posts they are helpful im about to go pull the drivers side injectors and change the nozzels outboy the driver side is the tuffest to do outa the two specialy seein that ive got this dang M>S cant jump around like a monkey anymore
Old Mar 10, 2011 | 05:57 PM
veggimaxny's Avatar
I don't know if this is possible becuase i didn't have to try, but i thought of trying boat plug.You know the Black rubber kind you stick in the hole and tighten. I wondered if you cranked it down good if it would hold on enough to pull the cup out. When i did mine it didn't take much to pull the injector up and the cup was stuck on each one. i bet it would work. Give it a try and let us know if it works. i think those things have a small nut on the bottom side so just be careful you don't loosen it to much cause the nut will fall into the cylinder you could always stick a peice of rag in there to plug the hole.
Old Mar 10, 2011 | 10:46 PM
jeeperjohn's Avatar
Hey thanks. Thats a great idea and I bet it would work. Anyway tomorrow is T day for tear it down so I will let you know. And thanks to all the great posts and information. It made me start to think I could do this and save a bunch of money over the stealerships.
Old Mar 10, 2011 | 11:03 PM
2500HeavyDuty's Avatar
yeah, if they dont come out i wouldnt mess with them, but if they do use a brass punch to drive them in with some red high temp loktite
