f-150 stock tach help,
Old Mar 6, 2011 | 09:37 AM
taggmann's Avatar
Default f-150 stock tach help,
I put a Cummins 4 cyl into a 01 F150 2wd. Its a fun truck still in progress.
Throughout my conversion I've wanted to maintain the factory ford look. Gauge-wise the only thing left is the tach. I got a Dakota tachometer interface for the "W" connection on the alternator. So, the Dakota gets pwr with key, Ground, input from the alt. (pulse). then sends the corrected signal to the tach.
If someone has a real schematic ,
My problem is what instrument cluster input wire or pin goes to the tach for signal?
Thanks!
Old Mar 7, 2011 | 03:19 PM
the_new_kid's Avatar
The wore you are looking for is the one for the cam position sensor I believe. Not the crank. The stock gauge reads off the cam position gear if memory serves me right. Also it will require a little tinkering because you will need to send it a 24 tooth pulse I believe.
Old Mar 7, 2011 | 04:49 PM
taggmann's Avatar
Thanks Newkid. any Idea as to the color code , I still have the harness but the sensor plugs are long gone.
Old Mar 8, 2011 | 06:19 AM
I do not have the book any longer for the color code. I used to have the Ford electrical book which is very detailed.
Old Mar 8, 2011 | 09:03 PM
taggmann's Avatar
I found a pcm pin-out for the 96 model year and it is different. It does show a tach wire though so If I can find a 01 pin-out I will tap it in. got the wire run, just gotta know which one to hook to
thanks
JesseJames288
5.9L 24V Performance
Jun 4, 2015 06:35 AM
wannadrag
May 25, 2015 03:07 PM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
Sophia'sJustice
Mar 5, 2015 04:06 PM
