01 ford 7.3
Old Mar 6, 2011 | 08:04 AM
turk's Avatar
Default 7.3 wont start
runs great but does not want to start if it has sit for more than a day i dont think it is the usaul suspects gp gp relay nor do i think it is an injector there is no smoke when cranking like there is no fuel but then it will out of nowhere it will light and run fine no stumble nothing can it be the lift pump if so it works but dont know at what psi or gpm it should work at any help
Old Mar 6, 2011 | 08:28 AM
CSIPSD's Avatar
How many miles on the truck?
What is the maintance history on the truck, Oil changes, Fuel Filter, Coolant...
Sound to me like you may have a leak down issue in the HPO system.
Welcome to the site BTW.
Old Mar 6, 2011 | 08:47 AM
turk's Avatar
170k it is new to me i serviced it when i got it kid i bought it from put less than 3k on it he was no help as far as history said it was hard to start when cold so would plug it in easy fix replaced gp relay / so if the hpo is leaking off how do you test and what is the fix
oh and thanks for the welcome
Old Mar 6, 2011 | 09:11 AM
powerstroke cowboy's Avatar
HPOP Could be leaknig down.. Let it sit for a day then pull the HPOP resevor plug (on the top of the Resevor) and see if there is oil in the resevor.. if there is no oil pure some in and see how it starts then.... If there is no oil in it that is the problem..
Old Mar 6, 2011 | 09:15 AM
turk's Avatar
if so what is the fix
Old Mar 6, 2011 | 09:17 AM
To tell you the truth i cant remeber
I think there is a valve in the HPOP resevor that need to be replaced along with new gaskets
Last edited by powerstroke cowboy; Mar 6, 2011 at 09:17 AM. Reason: Automerged Doublepost
Old Mar 6, 2011 | 09:22 AM
turk's Avatar
thanks knew there had to be something i was missing like i say when it fires all is well i will start the search thanks again
Old Mar 6, 2011 | 09:34 AM
yea they need oil to start.. and keep running.. Good luck on finding the problem.
Old Mar 6, 2011 | 11:43 AM
95powersmoker's Avatar
Have you tried plugging it in at night once to see how it starts the next day?
Old Mar 7, 2011 | 10:25 AM
turk's Avatar
thats the deal plugging it in still doesnt change the fact that if has sit for more than a day it does not want to start and seems to be getting worse have not had time to check hpo but sounds like it could be the problem
