dpf ?
Old Mar 5, 2011 | 05:23 PM
slowdog's Avatar
Default dpf ?
whats the best way to get rid of dpf , how hard is it , and how much $$
Old Mar 9, 2011 | 02:37 PM
EasternAggie's Avatar
The easiest way would be to get a DPF delete kit which will include the delete pipe and a tuner to clear everything up so it runs right. Might as well go ahead and get a turbo back exhaust while you're at it. If you just get a Smarty tuner and delete pipe, its about $800. If you add on an exhaust, the price will vary depending on what size and brand you get.
I would go ahead and get an EGR delete while you're at it for about $70.
Old Mar 12, 2011 | 04:08 PM
slowdog's Avatar
what will the EGR delete do ?? and how hard to put in ?
Old Mar 12, 2011 | 05:20 PM
yj junker's Avatar
egr delete gets rid od the egr and stops the egr from throwing soot into your engine,my opinion ,if you leave the egr ,it is about the same as pulling your air filter and throwing sand into the engine,I have a 09 with egr & cooler deletes ,dpf and cat gone and full 5" exh with a H&S minimax tuner and it works great and alot better fuel mileage,my truck had too many miles on it when I got it for warranty so I had no worries on putting this stuff on,I changed everything myself biggest part was taking the trans. crossmember out to swap the exh.
Old Mar 14, 2011 | 12:55 PM
Ive seen a couple of grid heaters that were almost completely caked up with soot from the EGR.
Old Mar 15, 2011 | 08:01 PM
slowdog's Avatar
i need to get rid of the cooler too ? thought coolers was good ???
Old Mar 15, 2011 | 11:09 PM
Not the EGR cooler. an intercooler is good though
stillcummin
Feb 18, 2016 08:13 PM
sleepysubie
12
Jun 23, 2015 02:21 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
mrweasel
Oct 25, 2014 05:47 AM
jmed795
Oct 7, 2014 03:51 AM
