04 gmc 2500 hd lb7duramax injector nozzels to fix the fuel in the oil problem
Old Mar 4, 2011 | 06:28 PM
unclecowboy's Avatar
Default 04 gmc 2500 hd lb7duramax injector nozzels to fix the fuel in the oil problem
hi everyone my name is travis and its my first time to post i am changing injctor nozzles because i have fuel in the crank case done a injector balance test and showed that 1&2 cylinders were the bad injectors im hopeing that just changeing the nozzels will fix my problems and allso i was wondering if i should pull the injector cups if none of them came out when i pulled the injectors they all came out very easy im only on the passenger side at this point also i got some up graded nozzels they are 50 hp this is my first time at this they are draggon flo nozzels i got a install kit and these nozzels i hope i dont need any thing eles,so any ways i wondering if i need to pull the cups,and also do i need to loctite the nozzels while im doing this any and all help and advise would be greatly appreiciated thankyou all so much ive been reading steady and this site is awsome all the info is so in depth and so much help thanks to you all again travis perry
Old Mar 10, 2011 | 01:05 PM
cfarley0210's Avatar
i dont think there is any need to remove the cups if they didnt come out with the injectors. if you do remove them then make sure your coolant is drained because coolant will dump into your cyl. and its not fun to get out. about your loctite thing im not sure what you want to loctite but you shouldnt have to loctite anything in the injectors unless it said to do it
Old Mar 10, 2011 | 09:18 PM
cummin_un_glued's Avatar
FormerVendor
loctite the bottom of the cups if they come out, but new nozzles will not fix your fuel in oil problem you will have to replace injector bodys
Old Mar 12, 2011 | 08:41 AM
boy thats a bummer the body of the injectors is defective or what,i inspected all of them and didnt see any cracks but that probly doesnt mean anything ,i did see a weird problem in the return down inside of the return i mean it looked like a small pit smaller than a pencil lead it looked like the injectors had been replaced by the numbers on the injector nozzels they were a little differnt than the dragon fly i aslso noticed thr body number csting was 77 and i have one from the junk yard to help learn it had a casting of 98 does that mean one is up dated or differnt would you know anything about this boy thanks for the help i really appreiciate it back to gether with the injectors so ill start it and see if it worked but i had trouble getting #7 in the cup i mean it finally whent in i did drain the coolant but i had to pull the glow plug to check to see if there was coolant it didnt seem to will it hydrolock the mmotor if there is a tiny bit that got in thier very very small amount frrom blowing air in the hole to clean up i use a plumming flute to clean the old loctite it worked great gosh thanks for the help really apreciate it thank you if you could give any more advise i need all i can get thanks again
Old Mar 17, 2011 | 09:46 PM
OK GUYS I GOT THE TRUCK FIRED UP today i have M.S so it was kicking my *** still is but i got the strenth to get er done today it has stoped the smoking at start up and the idle is much better and the the throttle respones is awsome i still have to install the airdogtwo and my rebuilt transfercase and a new stack thanks for everything you all ill drive get it back to work in a couple days plowing snow and hauling horses and live stock thanks for a great site
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
