Stuck injector
Old Mar 2, 2011 | 09:22 PM
Smoke 'em's Avatar
Default Stuck injector
i think my number 5 injector is stuck open, i get a puff of white smoke and it is hard to start when cold, starts fine after it has been running then shut off and started again, and almost no white smoke then. So how wud i go about fixing or cleaning a stuck injector??? Thanks guys
Old Mar 4, 2011 | 10:04 AM
connermcpherson's Avatar
Take the injector out, clean it real good, remove the nozzels and break clean it real good. See if that does the trick
Old Mar 4, 2011 | 10:33 AM
RAW's Avatar
RAW
I am curious to how you diagnosed #5 injector. Has rhe head gasket been ruled out at this time? If it is indeed an injector problem, perhaps try swapping injectors between cylinders to see if the problem moves with the injector, or stays with the cylinder.
Old Mar 4, 2011 | 10:40 AM
Smoke 'em's Avatar
im guessing its 5 because its the only one im continuing to have problems, how do i take the nozzles off?
Old Mar 4, 2011 | 10:59 AM
RAW's Avatar
RAW
If you have an infrared temp gun, you can check the exh manifold for temp at each cylinder. Do this with a cold truck otherwise the heat distributes and is difficult to check. A cold cylinder/section of manifold would indicate a dead cylinder. Then you will know which injector to chase.
As for the nozzle, pull the injector, and there is a "nut" on the injector that holds the nozzle in place. Remove the nut to access the nozzle.
Old Mar 4, 2011 | 11:43 AM
Smoke 'em's Avatar
wht do you mean when its cold? like start it then do it right away?
Old Mar 4, 2011 | 07:34 PM
dolla_hite's Avatar
yes thats what he means. because if it runs for awhile the manifold will get hot from the other cylinders.
Old Mar 4, 2011 | 07:43 PM
RAW's Avatar
RAW
Yes, a cold engine. Cold enough to touch. If you don't have a temp gun, you can use your hand, but be FAST and safe.
Old Mar 5, 2011 | 01:08 AM
Smoke 'em's Avatar
gunna use a buddy's gun tomaro, let ya kno my results, thanks
lowride
Oct 24, 2015 08:50 AM
Gm3500
May 7, 2015 11:01 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
Mar 5, 2015 05:02 PM
