electrical problem...HELP!
Old Mar 2, 2011 | 11:47 AM
12vkoalroller's Avatar
Default electrical problem...HELP!
i have been having some issues with my electrical system in my truck. the batterys have been reading an average of 12.4 volts when the truck is off. once in a while the GEN light will come on and the voltage meter goes all the way to max, and it will make my exhaust temp gauge and my fuel pressure gauge go crazy. if i shut the truck off it wont come back on. last night i was driving and my turn signal lights, brake lights and my reverse lights quit working. the headlights were still on. anyone have an idea of what this could be??????
Old Mar 4, 2011 | 07:50 PM
unclecowboy's Avatar
it sounds like you need to check and clean your grounds
Old Mar 7, 2011 | 03:14 PM
the_new_kid's Avatar
Sounds like a possible voltage regulator if it really is spiking that high.
I hope you did not burn out all your lights because if the voltage spiked as high as you said it did then you could have burned out the lights.
Also make sure you check all your grounds. Could be that too.
Old Mar 8, 2011 | 06:54 AM
ok thanks guys. if it the voltage regulator how would i fix that? im almost positive thats in the PCM...
Old Mar 18, 2011 | 07:26 PM
Red_Rattler's Avatar
High Tech Redneck
any news?
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
moparman70
Jul 30, 2015 12:38 AM
Dadslb7
Dec 9, 2014 11:05 PM
signoremint
13
Oct 21, 2014 07:21 PM
