Exhaust back pressure valve
Old Mar 2, 2011 | 07:46 AM
jakobengland's Avatar
Default Exhaust back pressure valve
i Have a 1999 7.3L PSD, How do i keep that loud hissing piece of crap from coming on (EBPV). ive heard you can turn it into an exhaust brake of sorts, has anyone heard of this or know how?
Old Mar 2, 2011 | 09:32 AM
fordornothing's Avatar
you can make it an exhaust break. there is a 2 wire plug on the left side of the compressor housing ant the front. find the power wire. cut it. connect to the wire coming from the plug. make sure it's not the end going to you pcm. you will fry it. then run it inside the cab to a switch. take another wire from the pos. side of the battery and go the the other terminal on the switch. turn it on and it should close. or if you don't want to do that. just unplug it. it will probably give an EBPV fault code or some thing similar...
Old Mar 2, 2011 | 11:19 AM
thanks i will try that when i get home tonight
Old Mar 2, 2011 | 04:15 PM
CSIPSD's Avatar
The plug is under the turbo on the pedistal, not up on the compressor housing.
To the original poster, the valve is there for a reason. Its built to help warm the motor up when its cold. If you dont like it, plug your truck in, or let it warm up properly.
Its turning on, because its doing its job.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Ward_59
Apr 28, 2015 04:59 AM
LTreis702
Feb 14, 2015 12:52 PM
