Intercooler?
Old Feb 28, 2011 | 08:08 PM
97CumminsDiesel's Avatar
Default Intercooler?
I was thinking about lowering my egt's and have a tight budget, too low for water/meth inj. right now Would acid dipping or stripping the flakey paint off my intercooler increase its efficiency much?
Old Mar 1, 2011 | 06:14 AM
Dallas Flywheels's Avatar
Not worth the time.
Old Mar 1, 2011 | 11:12 AM
bluedieselram's Avatar
cut a small hole in bottom of your intake box,get an oil filter cooler,put zmax in your truck
Old Mar 2, 2011 | 10:14 AM
justin c's Avatar
if he cuts a hole in the bottom of his air box he will be sucking dirt and **** threw his engine DO NOT DO THIS besides it looks like he takes his truck in the mud... acid dipping it isnt worth it BUT how good do u clean it after playing in the mud? it might be clogged hold a flashlight up to it and u should be able to see right threw it if its dirts pressure wash it but hold the pressure washer straight cuz if u dont it will bend the fins
Old Mar 2, 2011 | 01:35 PM
Yeah, I wouldn't cut a hole in the airbox , although I clean my airfilter religiously. But thank you for the advice! Would a engine oil cooler and Zmax really lower egts though? That seems unlikely to me..
Old Mar 2, 2011 | 05:06 PM
zmax yes it lowered mine about 90-100 farenhiet & the oil cooler should,if it doesnt itl help keep your engine run cooler though
Old Mar 2, 2011 | 07:03 PM
justin c's Avatar
i ment clean your intercooler sry i didnt say that when i was talkin about pressure washing also z max does work thats not a bad idea and and i have a crazy amount of work done to my truck and i flow almost 700cc of fuel and run 5k rpms and my oil never needed on kind of treatment (not saying it wont help just saying i never had to and i dont see how it would lower egts sence air doesnt touch oil but i have been wrong before) if u wanna lower egts and u were gunna spend the money to acid dip u might be better off just buying a water meth kit there is a few used setups for sale for 3-400 bucks with the controller and u get better mpg and in the summer u can run water and in the winter run washer fluid i hope this helps u
Old Mar 2, 2011 | 07:07 PM
the oil cooler mostly lowers engine temps
Old Mar 6, 2011 | 05:19 PM
yeah makes sense. i'll have to keep an eye out for a decent water/meth injection kit. Thanks
Old Mar 6, 2011 | 07:56 PM
justin c's Avatar
no problem there is a couple for sale on competitiondiesel its another forum im on.. and bluedieselram that makes since
