adrenilin problms
Old Feb 26, 2011 | 11:10 AM
silverbeast1345's Avatar
Default adrenilin problms
i have a mads smarty stacked with a quadzilla adreniline on my 01. i was drivein the truck fine with the adreniline set on 8 every thing was runnin fine. shut the truck down when i got back to the house. went to start it the next mornin it took forever to start an when it did it ran like crap an was throwin a bunch of dtcs. i then un hooked bolth programers then it ran fine again, then i put the smartys back on set on 4 same thing truck ran great as soon as i hooked the power up to the adreniline my check engine light came on. i was wondering if any body has had this problem or knows whats goin on cause im stumped
Old Feb 26, 2011 | 12:34 PM
chad83181's Avatar
Fill out your signature so we know what all you have done to truck. Do you have stock lift pump? Do you have a fuel pressure guage or know fuel pressure? That will give us a starting point.
Old Feb 26, 2011 | 09:26 PM
air dog 150 with a low presure light set at 5 lbs an my signature is updated
Old Feb 26, 2011 | 11:44 PM
blue24valvecummins's Avatar
with an air dog 150 i hope u don't ever see below 10psi if it goes down to 5 its kinda hard on the vp44. check ur truck for codes with ur smarty
Old Mar 2, 2011 | 07:43 PM
read the dtc thers two of them a p1693 an p0237. when i went to hook the wire up to the lead comein off my stelth cover the injection pump started makin bad noises knda like it was running dry. when i fired the truck up i had to pull the engine fuse because i had the key in my hand the truck was still runnin. the control pod didnt turn on either. im thinkin the box went bad some how
