6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
6.5 heads
Old Feb 26, 2011 | 08:05 AM
muderxtreme's Avatar
Default 6.5 heads
Does anyone know or have tried either double stacking head gaskets or de-stroking a 6.5 to run more boost. I've done it before with small blocks to run turbos and stuff but I dont really know much about the 6.5s and was thinkin about it when I rebuild mine
Old Feb 26, 2011 | 09:55 AM
92typhoon937's Avatar
well i dont think u can double stack head gaskets i dont think that would work out to well
there may be thicker gaskets available im not sure though
Old Feb 26, 2011 | 01:11 PM
Woody35's Avatar
thats more of a cheater way to lose compression. if you run too much boost and too thick of gasket you have the risk of blowing the headgasket
Old Feb 28, 2011 | 03:05 PM
Ya I know its the cheater way but it was just a though. How about destroking a 6.5, anyone heard of that? Or even if you could stroke one by using a different crank like a 400 crank in a 350 sbc.only reason I'm asking is because I kinda want something different than the normal.
Old Feb 28, 2011 | 03:17 PM
93chummins's Avatar
If you want to know what you can or can't do to a 6.5td talk to Bill Heath at heathdiesel.com He has at least 20 6.5td and some run as high as 35psi boost
I am currently running 15 psi boost with no mods and no problems
Old Feb 28, 2011 | 06:06 PM
2MuchJunk's Avatar
You can't stroke or destroke a 6.5 with out offset grinding a crank. The 6.2 and 6.5 share the same stroke. You don't wan't to lower compression because it moves the top of the piston further from the pre chamber and hurts its ability to function properly.
Old Feb 28, 2011 | 08:59 PM
Alright then, I was just curious because I've done it with other motors but never a diesel. thanks to everyone for their imput
Old Mar 3, 2011 | 01:14 AM
gmguy's Avatar
gm does make different thicknessof headgaskets
greatlakes diesel
Feb 13, 2015 09:55 PM
detroitdiesel idi
Dec 27, 2014 10:03 PM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
