The More advice the better.
Old Feb 25, 2011 | 07:37 AM
nwright002's Avatar
Default The More advice the better.
I have an 08 stock. I am on a limited budget of $800. I am wondering what is the best way to go to get a little power, less than 100hp and get better fuel mileage. There are so many tuner options out there it makes my head spin. What is the best application for my needs????? I am open to any opinions from you guys because you guys know what you are talking about. Also where is the best place to purchase a tuner??? Hope to get alot of feedback.
Old Feb 25, 2011 | 08:08 AM
barkrulz's Avatar
Keep saving and get a 5" TBE and an H&S minimaxx with egr delete. You'll get your HP, MPG, and it will pay for itself over time depending on how much you drive. I figured it out once and it was around 35 tanks, for me. My MPG went up by about 50%. I was getting 11 in town 15 hwy and am at 16 and 22 now. So for every 3 dollar gallon i save about a buck, higher price of fuel equals quicker payback. In 35 tanks I would save 1295 bucks. Unfortunatly you can't break it up and buy one item at a time and use them seperatly.
When towing 12000lbs I really gained alot, i get 16-19 wind and topo dependant.
Old Feb 25, 2011 | 12:38 PM
CrazyLadysHubby's Avatar
What about the dpf delete? And you are getting 16-19 pulling 12000 lbs trailer? Is that calculated or OBD?? I find the obd can be way off. Ok I have to hurt my bank account now. And duh.. 5"tbe means you did the dpf delete.
Last edited by CrazyLadysHubby; Feb 25, 2011 at 12:41 PM. Reason: Calculated vs obd fuel mpg
Old Feb 25, 2011 | 07:11 PM
coors_man_2005's Avatar
when you buy exhaust im almost positive you can run 5.9 exhaust and save some $$$ as long as you have sims to kill the regen or get a tuner. and there are ways you can run code free w/o a tuner if you want exhaust and no tuner to start off with exhaust is a big time help and also there are some ppl making just a replacement peice that goes in place of dpf cat and exhaust which saves some money but you still have the resinator on the down pipe .. i like my smarty get good mpgs also
Old Feb 25, 2011 | 08:48 PM
nwright002's Avatar
thanks guys. i think im gonna start with a tuner. did some research today, which is better a smarty or smarty jr?
Old Feb 26, 2011 | 05:58 AM
MarineOne's Avatar
Get the Smarty Jr, and just pick up a piece of exhaust pipe from Napa or some place to do the delete. Cost on the pipe is less than 40 bucks, and the stock exhaust is fine until you start pushing alot of power.
Then you can save the moeny for other stuff down the road.
Old Feb 26, 2011 | 05:52 PM
mikeshauling's Avatar
Neither, he is NOT getting that while pulling 12,000 LBS.
Old Feb 26, 2011 | 08:58 PM
If hes not getting 16 what is he getting? I plan to regularly pull about 15K and Im getting about 10 now. Thats calculated.
Old Feb 27, 2011 | 12:02 AM
barkrulz's Avatar
Went 595 miles on odometer from last fillup to home, filled the next morning 35 gallons.
Old Feb 27, 2011 | 02:06 AM
when i pull my 38' toy hauler 16,500 dry weight and its far from dry when i pull never have actually calculated it but the over head says 11-13 (summer fuel) which i know was far more then my buddies power choke pullin a smaller lighter travel trailer ha ha gotta rub it in to him always pull on 60 hp tune
