07 front on my 01
Old Feb 20, 2011 | 09:22 PM
black smoke77's Avatar
Default 07 front on my 01
hi guys what exactly do i need to replace to put the 2007 front end metal on my 2001 f250? what parts? thanks
Old Feb 21, 2011 | 01:29 PM
Lange503's Avatar
just the bumper,grill, and headlights
Old Feb 23, 2011 | 03:30 PM
kpasichnyk's Avatar
i just did this swap on my 01 but kept the forestry bumper/wicnh combo i had . the way i did it was source out all the parts first.
first off is headlights, all the plugs EXCEPT for the headlight plugs will plug into the 07 headlights. you can pick them up from the dealer or a wrecker and splice them in wiring is simple. the bulb sockets that twist into the headlights for the markers and signals that the plugs go into will have to be from the 07 aswell because there on different angles than the 01 but like i said there the same dont no issues there.
mounting the headlights and grill into the stock header panel is easy, this is what i did. dfuser has a template on where to cut out on their site. cut small amounts , you dont want to cut to much. the 07 headlights mount in the two holes already drilled in the header panel above the stock headlight which require some clips to be bought from a wrecker or the dealer, and the lower portion of the light mounts in the two holes where the signal lens screws into.
if you dont want to cut yours you can always buy an 07 header panel.
the grill is pretty easy and mounts essentially the same as the 01 but since its taller so you cant use the lower clips that come with it, you have to zap strap it in.
hope that helps, any more questions just ask
Old Feb 24, 2011 | 12:38 AM
farmboy01's Avatar
Alligatorperformance.com Diesel Performance, DPF Delete kits, Diesel Performance Parts and accessories for your Ford Power Stroke, Dodge Cummins, Chevy and GMC Duramax truck. We're your #1 source for all things Diesel. We also offer bed covers, air i
this is a compleat kit that bolts on to the factory holes. i dont know if it would be cheaper to buy each part or this kit. thought id try to help
Old Feb 24, 2011 | 08:23 PM
double_d93's Avatar
I actually found everything you need except the plugs on eBay for around $500 with out shipping.
Old Feb 24, 2011 | 10:22 PM
Bigred7.3's Avatar
i did the 07 swap on my 2000 f250 i went and got the grill insert for the 07 so i didnt have to cut or modify the old one.
Old Mar 30, 2011 | 03:51 AM
01ford_f_350's Avatar
i did just the headlight swap on my 01 i used headlights from an 06 and it was fine i have a buddie that wants to do it to his 02 and i was wondering if the header panel was the same as the 01
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
Natenelson1
Jan 19, 2015 07:23 PM
