04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
BAD?
Old Feb 20, 2011 | 12:33 AM
DuramaxKid69's Avatar
Default BAD?
Can installing an LBZ be bad for an LLY????
And....
Can having an EGR blocker be bad????
Old Feb 20, 2011 | 12:37 AM
Horns's Avatar
Neither of those would be 'bad' if done right.
And just to make sure you know, neither the LLY nor LBZ have an EGR.
Old Feb 20, 2011 | 01:27 AM
BriteWhiteRam's Avatar
WRONG!!!!!!!! even some LB7's(california emissions trucks) have EGR's!!!!!!
There will be no negative effects to changing the mouthpiece, or blocking the EGR, you're probably going to hurt you engine if you don't block the EGR
Old Feb 20, 2011 | 01:58 AM
Horns's Avatar
Oops, forgot about those emissions crazy liberals.
Is it correct though that ALL duramax's had EGRs starting with the LMM or did they start before that?
Old Feb 20, 2011 | 09:24 AM
the LLY was the first series for all engines to have an EGR, the 07.5 LMM is the first series to have the DPF in the exhaust
Old Feb 24, 2011 | 01:01 PM
1AMatt's Avatar
Site Sponsor - 1aauto
EGR blocker plate and a banks finger stick will take care of ya Probably the first upgrade anyone should do to an LLY
Old Feb 24, 2011 | 01:15 PM
Farmboy 2.0's Avatar
Banks makes a finger stick?
Old Feb 24, 2011 | 01:24 PM
1AMatt's Avatar
Ha ha no Scott they do not make the finger stick, thank you for the correction. To be honest Im not sure why I said banks there. Actually who does make it? One or multiple manufacturers?
Old Feb 24, 2011 | 01:27 PM
I believe it is just kennedy diesel.
Old Feb 24, 2011 | 01:37 PM
1AMatt's Avatar
Yea that was the only one I could find after just doing some searching. Thanks for clearin that up
