buying a 94 F250 7.3 turbo
Old Feb 16, 2011 | 06:03 PM
desiljim's Avatar
Default buying a 94 F250 7.3 turbo
I am going to buy a 94 f250 7.3 turbo - 2 wheel drive - 162,000 miles. This is a beautiful truck very well maintained. It is a southern truck no rust.
I am wondering if this a good engine and if this is to many miles. How many miles can I espect to get out of it.
Old Feb 16, 2011 | 08:52 PM
Biggreen1's Avatar
desiljim,
Terrible engine-get a gas one. JK. My 97 7.3 turned 277,000 this week. Still pulling strong.
Congrats,
Tim
Old Feb 17, 2011 | 06:28 PM
desiljim's Avatar
Default 94 7.3
Thankx for the info. This truck will be my last i hope. Pull a heavy popup camper - poontoon boat- and a utility trailer ( not all at the same time ) I wonder about fuel consumption 18 mpg or so I hope. Got to be better than gas.
Again thankx Desiljim
Going to buy this truck. It's 2 wheel dr and it supposed to have a limited slip rearend. How can I tell if it does. I realy don't thick I want 2 wheel if not limited slip. Can I tell by the numbers on the rearend.
Jim
Old Feb 18, 2011 | 07:09 PM
95powersmoker's Avatar
Is it a Powerstroke? Or a turbo IDI? They had both in 94...
Old Feb 18, 2011 | 07:25 PM
BVFD54's Avatar
In 1994 you can find out real easy if it is a powerstroke or an IDI 7.3L diesel by the vin number. The 8th digit in an IDI is a K and the 8th digit in a powerstroke is a F.
Old Feb 19, 2011 | 04:00 AM
Sycostang67's Avatar
If it's an IDI, make sure you get the SCA's in the coolant if it doesn't have them already.
Old Feb 20, 2011 | 03:58 PM
desiljim's Avatar
Default Tahks for the info
Its a idi not ps. I still wonder about the rearend. What about the coolant additive?
Thankx for the info
desiljim
Old Feb 21, 2011 | 01:20 AM
The 7.3 IDI can suffer from cavitation if the SCA's aren't maintained in the coolant. Read this link, it will tell you everything you need to know about cavitation and how to prevent it with the SCA's.
Cavitation Article
Old Feb 21, 2011 | 04:44 PM
desiljim's Avatar
Thanks for the info. Not sure about this truck it has 162,000 on it. I am concerned about this SCA stuff. If I tested it and it was OK do you think I should buy it not knowing how long it had not been up to par?
I can't afford to buy the truck and have to put an engine it or have an expensive repair. Is cavitation a concern in all late model Desils? Want a Desil but am concerned about the cost of repair.
Thankx for all the info Desiljim
Old Feb 21, 2011 | 07:08 PM
Cbum's Avatar
Mine gets about 10mpg with the heavy steel bed and it is a crew cab as well mine is the idi turbo diesel .
