engine shut down
Old Feb 16, 2011 | 04:46 PM
mischa's Avatar
Default engine shut down
hi I've got an gmc 6.5 td and when i'm driving and pull up from a traffic light, my car just shuts down! i pull over and start again and drive away and it happens again, when i start the engine again and drive allong it looks like nothing happend because the car is behaving normal again. Anyone an idee what this could be????
Old Feb 16, 2011 | 04:53 PM
Whit's Avatar
Site Mascot
sounds like a fueling issue..............I bet yer fuel supply (lift pump) is out or very weak
possibly plugged fuel filter ????????????????
Old Feb 16, 2011 | 04:54 PM
mischa's Avatar
ok thank you very mutch is there a way to check this?
Old Feb 16, 2011 | 05:00 PM
Crazy's Avatar
sound like PMD going south on that are sign of PMD
Old Feb 16, 2011 | 05:02 PM
mischa's Avatar
pmd ?? :P i'm new in this kind of stuff
Old Feb 16, 2011 | 05:13 PM
Crazy's Avatar
PMD is what runs the injector pump black or some time grey box on side the IP witch goes bad lot cause heat most of more it to the front bumper on a heat sink
Other thing you want to check that play big part to the 6.5 are grounds there are 2 or 3 wires at the back right side on motor and there is also 2 ground straps there from the fire wall right under the a/c dryer 1 goes to back of right head the other goes to the frame those are the grounds for the computer then there ground wire on top of the injector pump and one at right fender next to the battery make sure the clean and tight
Old Feb 16, 2011 | 05:17 PM
mischa's Avatar
great thnx i'll look for it!!
how can i test it if its workong or not...?
Old Feb 16, 2011 | 05:18 PM
Crazy's Avatar
only good way test it if you had spear or know someone that has same motor
Old Feb 16, 2011 | 05:19 PM
mischa's Avatar
ok thnx
Old Feb 16, 2011 | 05:22 PM
Crazy's Avatar
here is site tell you how test that test didn't work me reason is PMD do many diff stuff when they go out
www.AccurateDiesel.com - PMD Installation Instructions - Accurate Technical Services, LLC
