SMARTY Settings
Old Feb 13, 2011 | 08:10 PM
Uncle Bubba's Avatar
Default SMARTY Settings
Ok, I've been playin with the Smarty for the last couple days. The question I have is that I have run all of the setting between economy and wide open, settings 2-9 and they all feel exactly the same and my 0-60mph times are almost identical on all of them.
Not complaining because it really did wake the truck up in the low end where I needed it, just don't understand why they're all so similar in performance.
Old Feb 14, 2011 | 11:54 AM
biged681985's Avatar
have u updated it? i had a friend who bout one and wasnt satisfied with it. ended up salein it to another friend, he updated the software and said it made a world of a difference.
Old Feb 14, 2011 | 02:53 PM
chad83181's Avatar
I,ve been told bigger injectors say 75-100 make a big difference.
Old Feb 14, 2011 | 03:19 PM
Jazz's Avatar
Injectors do make a difference but, the settings 2-9 are all the same power wise with or with out timing but throttle response and torque is there sooner on the higher settings.
Old Feb 20, 2011 | 07:33 PM
crusty_critter03's Avatar
jazz if that is true why would his 0-60 times be almost identical? if his torque was lower on the lower levels shouldnt it affect 0-60?
Old Feb 20, 2011 | 07:38 PM
heavy hauler's Avatar
Smarty for the 24v is only like 75 hp so there might not be than much of a difference between the levels or am I wrong on the horsepower.
Smarty=Cummins's Avatar
I have a smarty and wow when I go from 2 to 9 setting the truck becomes a monster and I haven't upgraded it yet. Have you set your timing, torque and duration to high yet.
Old Feb 20, 2011 | 07:39 PM
mysterync's Avatar
They were all the same, I dyno tested each one . There may have been some minor changes in power band location but all in all It was the same.
I generally lost about 40-70 RWHP with the smarty depending on level but it made the truck much more fun to drive!
Old Feb 20, 2011 | 07:42 PM
Are you losing fuel pressure? Could that be why you are not seeing more power. Running out of fuel supply. Just an idea.
Old Feb 20, 2011 | 07:45 PM
Smarty Chip is 140 horsepower and 400 ft lbs
