XRT Pro Q&A
Old Feb 12, 2011 | 08:36 PM
Kenny Rhea's Avatar
Default XRT Pro Q&A
Has anyone used the xrt pro feature advertised on H&S website turn off EGR system without removing any parts and if so how well does it work I have an 08 work truck that I would like to tune but dont want to put a lot of money in it. I'm guessing the DPFs will still clog
Old Feb 12, 2011 | 08:42 PM
If you run the XRT Pro you must remove the DPF.
Old Feb 12, 2011 | 08:46 PM
Kenny Rhea's Avatar
so this feature would simply replace the egr delete. Thank you
Old Feb 12, 2011 | 08:47 PM
It would disable the EGR but it still needs to be deleted.
Old Feb 12, 2011 | 08:50 PM
Kenny Rhea's Avatar
Default 09 3500
My friends truck is an 09 3500 He was previously running a bullydog and just switched to an h&S XRTPRO. We were wandering if he could stack the bullydog on stock tune just for the guages. I know he should of got a mini or black maxx but he ordered it before talking to me. If any one has info it would be gretaly appreciated. If it can be done how do you do it what order do you install the tuners
what is the point of this feature in your opinion Luke, I am very new to the 6.7's seeing as how I dont have one YET
Last edited by Kenny Rhea; Feb 12, 2011 at 08:50 PM. Reason: Automerged Doublepost
Old Feb 19, 2011 | 10:45 AM
Kenny Rhea's Avatar
Is anyone staking a bullydog with an xrt pro or know if it will work
Old Feb 19, 2011 | 12:37 PM
No need to stack.
Old Feb 20, 2011 | 02:23 PM
grayghost03's Avatar
This is not true, there are tunes with all emissions intacked on the XRT Pro. The increases are lower then with deletes. I ran them prior to deletes (for about 2 days) Then did the deletes, reprogrammed, then you will see the mpg increase.
Old Feb 20, 2011 | 06:05 PM
Kenny Rhea's Avatar
we only want to stack so we can use the guages that came on the bully dog we are planning to leave the bully dog on stock I think it should work but am not sure on how you go about installing 2 tuners which one should go in first
May 20, 2015 11:20 PM
Nov 5, 2014 07:00 PM
Oct 23, 2014 11:00 AM
Sep 27, 2014 08:10 AM
