got rid of the dead fish lookin down. pipe
Old Feb 12, 2011 | 03:12 PM
Joe_Jirinec's Avatar
Default got rid of the dead fish lookin down. pipe
And also got an intake truck runs like a raped ape now and rolls a little coal
Old Feb 12, 2011 | 03:45 PM
hpkns75's Avatar
Fixing to tackle the downpipe project on mine as well. Did you use a crowbar to do the firewall modifying?
Old Feb 12, 2011 | 07:42 PM
fordornothing's Avatar
i used a porta power with a clam shell spreader. and two 2x4's one on the fire wall and the other on the back of the head.
Old Feb 12, 2011 | 08:00 PM
hpkns75's Avatar
Would it be worth the hundred dollars to buy a porta power and save a lot of hassle and headache of trying to modify the firewall with a crowbar, or is it not as bad as what I have been told?
Old Feb 13, 2011 | 10:43 AM
I just used a crowbar and took the isulation out around the pipe such gave me like 2 in. The hardest part is getting the old one out. I used a sawsall and cut the top of the pipe off when it gets skinny from up top and the cut it in half from the bottom
Old Feb 13, 2011 | 07:50 PM
i just used a porta power because i had access to it. but you can use a crowbar. that will work too. and get rid of the insulation. it doesn't make that much of a difference heat wise on the fire wall.
Old Feb 14, 2011 | 04:15 PM
RattleBomb7.3's Avatar
crowbar or an axe handle anything that is atleast 2-1/2 to 3 feet long, just did this yesterday its the easiest mod ive done to the truck the hardest part is removing the old flat POS downpipe & make sure to have plenty of long sawzall blades too!! moving the seam in the firewall was a slam dunk
Old Feb 14, 2011 | 07:02 PM
hpkns75's Avatar
Exhaust should hopefully be here Wednesday and I will see what damage I can do this weekend. Thanks guys for all the tips, yall have been more than helpful.
Old Feb 14, 2011 | 09:41 PM
JC-6.9's Avatar
I ordered my downpipe today and will be here tomorrow looking forward to getting that squished one off the truck
