no spool???
Old Feb 8, 2011 | 01:31 PM
finkfarms's Avatar
Default no spool???
I have an 01 F250 which doesn't seem to be spooling turbo or building any boost if it is spooling. (He truck does have high miles. I am wondering where should I start to fix this problem???
Old Feb 8, 2011 | 06:51 PM
Lange503's Avatar
check all your intercooler boots and pipes, also your intake manifold and the boots on it, and the V-band clam on the back of the turbo, and hows your air filter look?
Old Feb 8, 2011 | 07:16 PM
finkfarms's Avatar
The filter is dirty
Old Feb 8, 2011 | 07:55 PM
joebob3093's Avatar
Moderator
clean or put in a new filter and check the intercooler tubes.
Old Feb 9, 2011 | 01:50 PM
Lange503's Avatar
Originally Posted by finkfarms
The filter is dirty
ok if its the washable kind clean it, if not go buy a new one, then check your intercooler pipes and boots, v band clamp on turbo, and the intake manifold and the boots on it too
Old Feb 12, 2011 | 11:38 PM
finkfarms's Avatar
Well I know turbo is spooling but no boost. I was wondering if the wastegate could be stuck open? I checked the boots and they all looked and felt good. All were tight to.
Old Feb 13, 2011 | 11:33 AM
95powersmoker's Avatar
Do you have a gauge on it? What boost numbers are you seeing at WOT?
Old Feb 14, 2011 | 10:49 AM
finkfarms's Avatar
There is no gauge on the truck. We were told to replace wastegate that it wasn't working.it is dumping all pressure before it can build
Old Feb 14, 2011 | 11:42 AM
PHPDiesel's Avatar
Sponsor
Do you have actual numbers?
If not, you're chasing your tail on GUESSING that you have no "spool".
Whitereaper12v
13
Jan 25, 2015 07:05 PM
wpg6.5
5.9L 12V Performance
9
Jan 7, 2015 08:19 PM
GreenDieselF
Oct 20, 2014 02:05 PM
