2003 dodge doesn't like running
Old Feb 7, 2011 | 07:54 PM
6.2Lturbo's Avatar
Default 2003 dodge doesn't like running
the truck starts up fine and might idle ok or nearly stall then fire back up and now it has started stalling on me. When shifting gears the throttle sometimes responds like it should and other times it takes a few seconds for it to respond. i have just replaced injector but it was doing it before i replaced them, they were changed because of mileage. NEED HELP
Old Feb 7, 2011 | 08:24 PM
Red_Rattler's Avatar
High Tech Redneck
Fuel pressure readings? What are you running for a lift pump? How many miles?
Old Feb 7, 2011 | 09:07 PM
6.2Lturbo's Avatar
don't know fuel pressure but the lift pump is only a month old and it is the stock in the tank one. it has 344km on the truck the truck pulls fine under heavy accel and there doesn't sound like there is a miss when it is running smooth
Old Feb 8, 2011 | 01:00 PM
cummin_un_glued's Avatar
FormerVendor
Fca possibly would have to have some live data readings to tell for sure or they are only like $145 and probally needs replaced anyways
Old Feb 8, 2011 | 07:01 PM
6.2Lturbo's Avatar
were is that located and do you just get it through cummins
is there anyway of checking it with a multimeter
Aug 13, 2015 11:50 AM
DSM1988
Jan 25, 2015 07:23 PM
Dec 12, 2014 12:30 PM
Nov 3, 2014 08:10 AM
elkmaniac
Oct 29, 2014 07:01 PM
