2000 DODGE 2500 NO START
Old Feb 7, 2011 | 10:15 AM
RandoH's Avatar
Default 2000 DODGE 2500 NO START
Ok guys so here goes, 00 2500, Banks powershot kit ( yeah I know it was there when I got it). When I tried to start it this morning , nothing, the starter didnt even click. The resister on dash side clicks as does the one in the box under the hood. Any ideas? I cleaned the battery connections at the battery which were not too bad but a little corroison and even gave the starter a little tap ( old school thinking here). Finally it cranked right up like nothing was wrong. Any ideas? i was going to start with cleaning connections really well. Suggestions?
Old Feb 7, 2011 | 10:41 AM
celticnonic's Avatar
I would start by checking the starter wiring and terminals for loose/bad connections at the solenoid
what was the outside temperature when you tried to start the truck? I have seen starter solenoids not want to engage in cold weather because they get stuck, and since you "tapped" the starter, there is a good chance that was the problem... also could have been a loose/bad connection at the solenoid
Old Feb 7, 2011 | 10:49 AM
RandoH's Avatar
It was probably 20 something outside. The truck had been plugged in and was sitting all night. I will check the connections to those but sounds like I may be in for a starter change huh?
Mac1997
Jul 13, 2015 05:08 AM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
