Starts and idles but runs like crap
Old Feb 4, 2011 | 08:56 PM
trisha1's Avatar
Default Starts and idles but runs like crap
1997 GMC 3500 6.5 Power Diesel Truck starts and idles but when pedal is applied it spits, sputters, smokes white...IP replaced at 80,000 miles, turbo-booster replaced at 160,000 miles, PMD was moved when IP was replaced. Truck is now at 173,000 miles. Have tried draining the tank, put a new fuel filter in. Can anybody help me out?
Old Feb 4, 2011 | 09:14 PM
collinscummins's Avatar
sounds like you might have a head gasket issue
pull the dipstick and if it looks like it has a chocolate milk color to it, its probably that, also some other symptoms to check for are oil in the overflow tank, sometimes that will happen,bubbles will sometimes come back thru the radiator too with the engine running, pull the radiator cap and check for that. To me it sounds like a blown head gasket already tho
Last edited by collinscummins; Feb 4, 2011 at 09:14 PM. Reason: Automerged Doublepost
Old Feb 4, 2011 | 09:52 PM
Crazy's Avatar
First all are you getting any codes
make sure the Lp is working buy putting 12V right to lp see how it runs , it also could be bad PMD
Old Feb 4, 2011 | 09:59 PM
whats a pmd?
Old Feb 5, 2011 | 10:47 AM
trisha1's Avatar
oil is fine no bubbles in radiator sometimes it will smooth out but not for long
Old Feb 5, 2011 | 06:33 PM
Woody35's Avatar
do the 2000 rpm test
Old Feb 5, 2011 | 08:30 PM
trisha1's Avatar
need help my truck runs good untill you press gas pedel wont go over 2000rpm and smokes white please if you can help i need it 1997 gmc 3500 6.5
does my 1997 gmc 6.5 have a egr and where is it thanks for the help
Old Feb 5, 2011 | 09:23 PM
Crazy's Avatar
Well Trish1 if it 97 truck you should be setting of SEL what are the codes to help you
Old Feb 6, 2011 | 08:27 PM
trisha1's Avatar
i am not getting any codes in my obd2 no check eng light
need help still having the same
Old Feb 6, 2011 | 09:48 PM
Woody35's Avatar
does it go away once your truck is warmed up? kinda sounds like a ip though
