4k gvsk into a 3k gvsk
Old Feb 4, 2011 | 03:58 PM
keithduke01's Avatar
Default 4k gvsk into a 3k gvsk
i am about two hours from installing a set of governor springs in a buddys truck but he bought a 4k kit. i have read on other sites that you can leave the center spring out of the 4k kit and make it a 3k then add the center springs when you get the 60lb valve springs to make it 4k. is this true or do i need to wait to install the kit?
Old Feb 4, 2011 | 04:28 PM
Red_Rattler's Avatar
High Tech Redneck
Just do the 4k and be done with it. As long as you dont go over 3200rpm you will be just fine
Old Feb 4, 2011 | 04:38 PM
i would but this guy drives everything like he stole it! and in his case its always to be safe than sorry!
Old Feb 4, 2011 | 04:55 PM
High Tech Redneck
Then in that case yep leave the middle spring out
