lots of noise
Old Feb 2, 2011 | 12:23 PM
tennwalkers's Avatar
Question lots of noise
I installed a new down pipe on my 1995 7.3 psd and I am getting a lot of noise now sounds like pipe is hitting somewhere but upon inspection it has clearance all around. cannot figure where noise is coming from. anyone have an idea? could it be the material the pipe in made from? maybe it is too thin metal?
Old Feb 2, 2011 | 01:02 PM
95powersmoker's Avatar
I would think its either vibrating on the cab or uppipe or you are just hearing the exhaust more because you have an aftermarket downpipe. Does it have a vibrating sound to it? If so, its your downpipe touching the firewall or somewhere else.
Old Feb 2, 2011 | 01:10 PM
checked all pipe is not touching anywhere up pipes firewall ect. sounds like exhaust leak but it has none it make vibration noise just under right side floor board like it is hitting the floor but it is not touching anything this is a stumper huh? I am thinking maybe pipe is too thin metal maybe but it is thick grade
Old Feb 2, 2011 | 01:15 PM
I doubt its the thickness of the DP.
Does it make the noise all the time or just when coming to stops, taking off... etc?
Old Feb 2, 2011 | 02:29 PM
it is worse when taking off real bad when turning also maybe a clearance problem due to flexing
Old Feb 2, 2011 | 03:44 PM
How much clearance do you have on the firewall?
Old Feb 2, 2011 | 04:07 PM
joebob3093's Avatar
Moderator
i would almost bet that its hiting the firewall. just because it has clearence at a stop doenst mean it will have clearance when the engine is ratteling around.
Old Feb 2, 2011 | 07:24 PM
OceanDiesel's Avatar
Is it an auto? If so, make sure your trans. dipstick tube isn't rattling on your downpipe.
Old Feb 7, 2011 | 11:22 PM
95-SimpsonOBS's Avatar
im with joebob, you have flex in the exhaust so it can move, it might be hitting the fire wall. taking off, turning, stoping, all the ones you listed where its the worse is when the exhaust will move
Old Feb 15, 2011 | 09:22 AM
got it taken care of thanks for all the help. removed down pipe and used porta power spreader with wood block bent the floor up about 2 inches and this stopped all noise once again thx for the help
