EGT's
Old Feb 2, 2011 | 12:57 AM
Rogers21's Avatar
Default EGT's
so the other day I took dads 97 to reno about a two hour trip, first half has hills second half is flat I was watching his EGT's and they were running between 400, and 900 never got hotter than 900, 600 seemed to be the norm, on the way back they ran at about the same with a bed full of sheet rock, so my question is in all my learning so far of the 7.3 whats considered hot EGT's for the obs? how about for the 99-03 due temps run about the same, are my temps hot or running fairly average
Old Feb 2, 2011 | 01:30 AM
joebob3093's Avatar
Moderator
Default Re: EGT's
Im about 700 crusing. Your temps seem just fine. Red line for EGTs is 1250. Anything over that you have the chance of breaking stuff.
Sent from my DROIDX
Old Feb 2, 2011 | 11:01 AM
OceanDiesel's Avatar
600 is normal for cruising, and with big hills, 900 isn't bad either.
Old Feb 4, 2011 | 11:33 AM
Rogers21's Avatar
good to hear then, is 1250 a hot number for all 7.3's or just the OBS.
Old Feb 4, 2011 | 11:39 AM
95powersmoker's Avatar
All 7.3's. Getting over that for short blurps is ok, but if you pin it to 1500 and hold it there for a minute, your asking for a new engine.
Old Feb 8, 2011 | 10:01 PM
fordornothing's Avatar
My buddies old PSD was a 94. he was pulling about 12k for about an hour doing 85- 90 mph. he melted off 1500 degree paint. how is it that the engine is still good? and he has no gauges so i have no idea what his temps were at.
he had the paint on the y pipe for his stacks.
Last edited by fordornothing; Feb 8, 2011 at 10:01 PM. Reason: Automerged Doublepost
Old Feb 8, 2011 | 10:04 PM
I doubt that his y pipe got to 1500 degrees. Just cheap paint.
Old Feb 8, 2011 | 11:01 PM
joebob3093's Avatar
Moderator
i have 1500* paint on my manifolds and its gone now. my truck as never seen 1350+
Old Feb 9, 2011 | 10:00 PM
well the can said 1500 degree. but it didn't burn off. it actually melted off.
Old Feb 9, 2011 | 11:48 PM
Awesome. Fact of the matter is. I highly doubt your friends y pipe in the bed got 1500 degrees. I have my Pyro sensor in the exhaust manifold which is as close to engine heat as it gets and I have yet to hit 1500.
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
TheDirtyDozen
Nov 16, 2014 02:56 PM
