DTC P0380
Old Feb 1, 2011 | 08:09 PM
dmaxtothemax's Avatar
Default DTC P0380
DTC P0380
Ok, so the code reads "Glow Plug Feedback Curcuit"....
What is the problem and how does it get fixed???
Old Feb 1, 2011 | 11:12 PM
BriteWhiteRam's Avatar
If its is a FE(federal emissions) truck then it is probably the Glowplug relay, from the research I did it would appear that its about $70 at a GM dealer for the whole glowplug controller
The gow plug relay is mounted on the drivers side valve cover at the very rear behind the turbo outlet pipe. It's a small black plastic box with a 4 wire plug on top of it and then 3 large studs with big cables hooked to it. The relays in it are sealed and you cannot inspect the points inside of them.
Part# 97371491
Hope that helps you
Old Feb 2, 2011 | 08:25 AM
thanks soo much man, i'll take a peak at it and get the part and change it out... We will see if this code will go away...
Old Feb 26, 2011 | 05:10 PM
Durado's Avatar
Did changing the relay get rid of the code? My truck has been throwing that code on and off all winter, but the truck never had a problem starting in 5 degrees without being plugged in.
Old Feb 26, 2011 | 06:13 PM
I havn't had a chance to get to it... but I don't notice a difference with or without the code either... I do plan to fix it at some point tho...
Old Mar 4, 2011 | 12:46 PM
2500hd Duramax Freak's Avatar
been having the same problem also have to keep clearing the code with the banks pda. but it comes up every time i start the truck.
Old Mar 5, 2011 | 10:57 PM
I don't think it's expensive or hard to do... it's just that i've got a baby due in a couple months, building a house as owner/builder/contractor/sub-contractor, and got everyday life and 40+ hours a week of work going on sooo i've been spread pretty thin lately and the dmax has been on the back burner for a little bit... can't wait to get time for the truck again...
if you get yours changed out before i do, let me know if your code goes away...
Last edited by dmaxtothemax; Mar 5, 2011 at 10:57 PM. Reason: Automerged Doublepost
JJ Diesel
Mar 20, 2016 07:39 PM
daniel2500
Apr 27, 2015 06:04 AM
