1982 6.2 dura air in fuel lines
Old Jan 30, 2011 | 06:49 PM
MichaelMotion's Avatar
Default 1982 6.2 dura air in fuel lines
Stranded,,how do I purge fuel lines ,,,see air in clear hose
Old Jan 30, 2011 | 07:57 PM
2MuchJunk's Avatar
The only way I know of to purge the air out of the fuel lines is to loosen the injector lines and crank the engine till fuel comes out.
Old Jan 30, 2011 | 11:14 PM
Default Thankyou
Thanx,,that got me off the side of the road,what i did is pressurize the fuel tank with a rigged fuel cap and a line off a compressor,then I bled the primary fuel filter outlet line and then the secondary fuel filter line,sealed them back up with solid surge of fuel running through fitting,,,,and boom boom boom allthewayhome
https://www.dieselbombers.com/images.../JC_hurrah.gif
Question ?????? On this fuel system if I find a leak in the hardened lines (metal tube),Can I cut out section and replace with heavy wall fuel hose?
Old Jan 31, 2011 | 12:38 AM
2MuchJunk's Avatar
It depends on which metal line it is. If it is a line running from the injection pump to the injector no if it is any line before the injection pump you should be able to.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
