please help
Old Jan 27, 2011 | 11:39 PM
TOWELD's Avatar
Default please help
My buddy just bought a 2000 f250 7.3 120000 miles and injecter #5 is no good if anyone has a good one to sell please let me know. Money is a little tight. I'm located in thousand oaks california 91360 so anything local would be cool or shipping is cool to 8057968717
Old Jan 28, 2011 | 09:15 AM
CSIPSD's Avatar
First I have to ask what makes him think the injector is "bad". Whats it doing to lead you to a bad injector?
Old Jan 28, 2011 | 10:43 AM
95powersmoker's Avatar
120k miles and a bad injector?
I'm with Joe, what's going on with the truck that you think one injector is bad?
Old Jan 28, 2011 | 11:38 AM
TOWELD's Avatar
He told me that he felt a studder and I told him to check icp ipr cps motor oil air filter fuel filter and he did everything and it didn't go away so he took it in and the guy he took it to told him there is a problem in clynder #5 either injector or just a dead hole and that's all I know
Old Jan 28, 2011 | 12:45 PM
turbostang7's Avatar
i don't know much about fords, but my work truck is a 7.3 and it did this, was the injector harness. something else to look at instead of throwing away good parts
Old Jan 28, 2011 | 12:47 PM
Ya, with that low of miles, I would be looking towards the uvch... Might do a compression test also to make sure.
Old Jan 28, 2011 | 05:16 PM
CSIPSD's Avatar
Need to run a Cylinder contribution test, watch the rotational values... Buzz test...
Once you get that done then if that points you in a direction go from there.
If nothing definitive then start looking at a compression test and a leak down test.
Old Jan 28, 2011 | 10:45 PM
TOWELD's Avatar
I just talked to him and he said some one did a buzz test and it was weak or something so idk but I did tell him about the uvch and he wants to check but is it worth it to look if he has already done the buzz test
Old Jan 28, 2011 | 11:45 PM
CSIPSD's Avatar
Weak buzz could be a wire harness issue, could be an IDM issue... Does not mean the injector is bad.
Old Jan 30, 2011 | 09:43 AM
TOWELD's Avatar
That's what I was thinkin. Better to start cheap and work up from there
