Need some advice
Old Jan 26, 2011 | 05:00 PM
Razram55's Avatar
Default Need some advice
So i recently bought a 99 Dodge Ram 2500 24v. I want to get something like 100hp injectors. What other upgrades will i need to do to be able to run this size injectors? Will my stock vp44 handle it? What upgrades will i need to do to my turbo? And what lift pump would you suggest? Thanks
Old Jan 26, 2011 | 05:49 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
#1 is gauges, you need Pyro and Fuel Pressure for sure, with out a doubt! You need to know what your truck is doing before you start laying the a$$ to her!
I also have the same truck as you. I would suggest getting a tuner for now. Heck with the injectors. GO grab yourself a AirDogg lift pump and an Quadzilla Adrenaline with Pulse. The Pulse gives you ALL the gauges you need!! They even have a fuel pressure add on!
You will CRAP yourself when you drive it on stage 10. You wont need bigger injectors first. Just get a tuner for now... When you get bored with that THEN get a turbo and injectors!
(If you get a Quad ADR with Pulse then you will get Pyro gauge with it and it will feed back a lot of other sensors.
Old Jan 29, 2011 | 10:26 PM
Razram55's Avatar
if i were to get 100 to 125hp injectors what would i need to do to support the extra need for air and fuel? would my stock vp44 and stock turbo handle them?
Old Jan 29, 2011 | 10:38 PM
I wouldnt jump in on injectors first. You need a quality lift pump first... Not only to support the mods you want to do BUT because the stock stuff is garbage! They FAIL out of nowhere and when they do you can kiss your 1800$ injection pump goodbye!! There have been FOUR lift pumps on my truck that I KNOW of! Stock, a replaced stock, 2 holley black POS lift pumps, one of which I put on after the one the prior owner put on left me stranded!! Then finally my AirDog 150!!
After that i STILL wouldnt get injectors. They add some fuel of coarse BUT they dont just GIVE you 125hp. They can SUPPORT 125 more horses. Its a flow rating thing! Soooo get a GOOD tuner. Maybe one that monitors gauges too like a Quadzilla Adrenaline w/Pulse or Edge Attitude w/ Juice.
You will CRAP YOUR PANTS when you see what timing AND fuel can do to your truck.. Then STUD it. Download some NASTY tunes and hold on to your pants! When you get bored with that THEN add injectors and compound turbos!
Old Jan 29, 2011 | 10:43 PM
Razram55's Avatar
this i understand, i plan on getting an air dog system and a tuner. but when i do decide to go with injectors will my injector pump and turbo handle that much of an upgrade in injectors?
Old Jan 29, 2011 | 10:47 PM
01quadcab's Avatar
I would go for a max of 75 hp injectors on a hx 35. your stock vp will handle tons more power. I say get a set of gauges a drag comp and have fun. your trans will be the next issue or clutch depending on what ya have
Old Jan 29, 2011 | 10:52 PM
Razram55's Avatar
I have seen a kit to convert the stock hx35 turbo to a hx40 hybrid turbo. It has a different housing and a different turbine. Anyone know anything about it?
Old Jan 29, 2011 | 10:58 PM
My buddy Monster12Valve has that... He says he doesnt really like it. I heard it spools slower. I cant honestly say though. The hx35 will push you to 30psi safley unstudded.
Old Jan 29, 2011 | 11:06 PM
Mr.Krabs's Avatar
I've got RV275s in mine,it works fine,still have the boost elbow in my wastegate hose,so it makes 32psi of boost,no computer and never gets hot,you won't NEED anything to run the 100s,but you should buy some gauges.
If you aren't pulling heavy I would not think you'd need a turbo upgrade,but I don't know for sure.
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
twm011
Feb 24, 2015 09:11 AM
jrsavoie
Feb 6, 2015 09:44 PM
lifted07sierra
Nov 6, 2014 08:24 AM
