ABS and E brake lights
Old Jan 24, 2011 | 07:46 PM
randazzo58's Avatar
Default ABS and E brake lights
I was wondering if anyone is having the same problem as me...'01 lb7 everytime the truck is running the E brake light and the ABS lights are on...The E brake is disengaged and the ABS definately works...sometimes the lights don't come on right away, like clockwork they always do no matter if it's 2 minutes after startup or 15 minutes. Does anyone else have this problem and does anyone know how to fix it? The dealership (which went out of business since) told me it was the computer module and it would cost $500+ to fix. I definately don't want to spend that much money just to have two lights shut off in my cluster. ANY help would be GREATLY appreciated!
Thanks in advance.
Old Jan 24, 2011 | 08:00 PM
KuNtRy BoY's Avatar
I am actually having the exact same thing on my 01. Hope someone chimes in.
Old Jan 24, 2011 | 08:21 PM
randazzo58's Avatar
someone on diesel place just told me it's the EBCM, which is about $500 new or so I have heard from my local dealership which has since gone out of business since I had it diagnosed there...I didn't know if they were trying to take me for a ride or not so I figured I would ask around on here....I don't know about you, but I don't feel like paying $500 to shut two lights off in my cluster.
Old Jan 24, 2011 | 08:30 PM
KuNtRy BoY's Avatar
Ya me either, doesnt seem to be causing any harm.
Old Jan 26, 2011 | 04:15 AM
2500HeavyDuty's Avatar
sometimes the ground can be bad for the ebcm, there is a ground cable on the frame right under the drivers door close to the A frame.
pull the bolt out and clean up the contacts and put a new bolt in.
Old Jan 26, 2011 | 06:50 AM
DieselCrawler's Avatar
i to have done the ground cleaning on ALL my grounds. fixed all problems i was having.
Old Jan 31, 2011 | 05:11 PM
randazzo58's Avatar
well I cleaned the area surrounding and replaced the bolt for the ground on the driver's side under the cab (which I believe someone on here said was the ground for the ABS system) the light came on after about two minutes of the motor idling. It didn't seem to help anything...are there any other grounds that might be connected to the brake or abs system that might help my situation?
Old Feb 1, 2011 | 07:49 AM
dmaxtothemax's Avatar
i dont' know if this will help, but my front hub ABS sensor wires where loose enough to rub the wheel and it cut them in half causing the light to come on... I replaced just the sensors and all is well now... not sure if that will help, but something to look at also...
cjt8569
Sep 29, 2015 06:39 PM
Hawkeye O'nelove
Sep 26, 2015 05:42 PM
wolf1365
Jul 31, 2015 03:43 PM
Gitana
Nov 25, 2014 06:25 PM
ValleyF250
Nov 1, 2014 07:56 PM
