Holset Model: H20
Old Jan 22, 2011 | 06:49 PM
AF1CUMMINS's Avatar
Default Holset Model: H20
Before I get hammered on the search tab, yes I did search and the only thing that was comin up was water/meth kits. So the turbo in question is on a Cummins generator and the on the tag instead of saying HX40 or HX50 and so on all it gave was a serial number and then Model H20. Does anyone have a clue what the specs on this would be or where I could find them. I'm trying to build a twins set on the cheap. Any help is really appreciated.
Old Jan 26, 2011 | 10:00 AM
EasternAggie's Avatar
You can always get one of those fancy tools and measure the wheels to see what you're working with. With enough fabbing, you can probably make anything work
Looked it up. You sure its not an HX20? Says it was used in light duty commercial engine applications up to 4 liters of displacement (so about 240ci).
www.cummins.com/turbos - Holset HX20-25-27
If so, its going to be smaller than your stock HX35. I believe the bigger the number, the bigger the turbo on this series of Holsets.
Last edited by EasternAggie; Jan 26, 2011 at 10:00 AM. Reason: Automerged Doublepost
Old Jan 26, 2011 | 10:42 AM
AF1CUMMINS's Avatar
No, I've actually found out that it's not a zero. That zero is a D. Apparently they put a slash mark / through the zeros on the stamps so you can tell the difference. It's actually a H2D. I searched that one and found some info, but not much. I would measure, but I don't have one of those fancy tools.
Old Jan 27, 2011 | 12:32 PM
I found anywhere from a 62-66 on the compressor and 77-78 on the turbine. Exhaust housing is about 25cm or so.
Old Feb 1, 2011 | 09:19 AM
AF1CUMMINS's Avatar
Oh wow, that's a big *** exhaust housing. I wonder it that could be modified?
Sep 2, 2015 01:30 AM
Jul 21, 2015 07:50 AM
Cumminsfreak24
May 6, 2015 04:56 PM
Feb 12, 2015 03:00 AM
gunman41mag
The Sportsmen's Lounge
Nov 4, 2014 08:42 AM
