96 f250 7.3 no crank no turnover
Old Jan 19, 2011 | 08:20 PM
robsford's Avatar
Default 96 f250 7.3 no crank no turnover
96 ford f250 7.3L powerstroke
i had a problem where when i turned the key there was no crack and the motor would not turn over..i replaced the starter selenoid and that problem went i away.. at least i thought it did but the problem came back i am getting power inside as far a lights and radio dash all that just when i turn the key she doesnt budge at all no crank no turn no noise at all.. appreciate the help..
Old Jan 19, 2011 | 08:23 PM
ccarrier's Avatar
check the #22 fuse
Old Jan 19, 2011 | 08:30 PM
robsford's Avatar
Where is that fuse under the hood or inside the cab.. What fuse is that
Old Jan 19, 2011 | 08:58 PM
97dieselnewb's Avatar
It's under the hood drivers side behind the air cleaner. It's a 30 amp maxi fuse, 3 bucks at any parts store, or well equipped gas station
Old Jan 19, 2011 | 09:21 PM
robsford's Avatar
The fuse has an s shape to it.. Not cracked but how can I tell if it's out.. If it's fine whatelse can I check?
95powersmoker's Avatar
When you turn the key does it just click?
If all your fuses are good, take a screw driver and jump the starter solenoid. If still nothing, i would say its your starter.
I had this happen about a week ago. Take your starter off the truck and run it down to O'rielly's and have them bench it.
Old Jan 20, 2011 | 08:47 PM
robsford's Avatar
No click no noise I turn the key to crank the motor and nothing happens.. The starter solenoid is on the starter or on the inner fender?.. Do I just turn the key til the wts turns on then I try to short it or do I need to have someone crank the key
so i tried to short the starter selenoid and i heard a click..
Old Jan 20, 2011 | 11:16 PM
Sounds like a bad starter. Had mine go out on me a week ago.
Old Jan 20, 2011 | 11:26 PM
robsford's Avatar
so ill pull it out tmrw and take it down to oreillys and have them check it out.. i heard that bc the diesel starter draw so much power a bad one will somehow show up as good?.. u have ur checked out or u just buy one?
Old Jan 20, 2011 | 11:31 PM
Buy one at auto zone if it doesn't fix your problem return it, they take 20 min tops to pull out and put in a new one
