98.5-02 Cummins 24V 5.9L VP-44 Tech Talk Tech Articles for the 2nd Generation Cummins 24V 5.9L VP-44 Engines.
24V Valve Lash Limits
Old Nov 24, 2007 | 12:57 AM
DB Admin's Avatar
Banned
Default 24V Valve Lash Limits
Minimum
Intake
0.152 mm (0.006 inch)
Exhaust
0.381 mm (0.015 inch)
Standard
Intake
0.254 mm (0.010 inch)
Exhaust
0.508 mm (0.020 inch)
Maximum
Intake
Exhaust
0.762 mm (0.030 inch)
Adjustments should only be performed when the engine coolant temperature is less than 60 °C (140 °F).
Old Nov 24, 2007 | 01:34 AM
Mr. Miyagi's Avatar
The engines like the tighter tolerances for top end and looser tolerances for low end.
Old Nov 24, 2007 | 12:22 PM
Crawler's Avatar
I run either 8 intake 18 exhaust for stock trucks.
and 10 intake 20 exhaust for modified.
Unless they have a custom cam. Then things can change.
~Wes~
Old Dec 1, 2007 | 08:27 AM
Mopar1973Man's Avatar
Here is a simple write up on how to adjust you valve lash...
http://mopar.mopar1973man.com/2002%2...adjustment.htm
Old Dec 23, 2007 | 09:28 PM
Wyatt Earp's Avatar
You sure make that look easy.
Old Jan 23, 2008 | 01:55 PM
Funny part it is easy...
RA113024
Mar 13, 2016 07:42 PM
Str8sixpack
Feb 28, 2015 11:32 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
