06 3500 megacab trans problem?
Old Jan 17, 2011 | 10:48 PM
colemantaxidermy's Avatar
Default 06 3500 megacab trans problem?
Been asking around everywhere to get help with my pickup trans problem. 2006 5.9, 3500 mega cab, automatic.
When coming to a stop, you can feel the converter lock up right before you come to a complete stop and stall the engine while you have your foot on the brake. Everything works and shifts fine going down the road, including the tow haul, overdrive and all shift points.
I replaced the lockup solenoids and a couple of pressure switches in the trans, and still does the same thing.
It's impossible to drive on icy roads, because the rear wheels don't want to stop! It did this a couple of months ago, and quit on its own. Then, out of the blue a few weeks ago, it started doing it again.
Anyone have any suggestions?
Thanks
Old Jan 20, 2011 | 03:14 PM
Default bad luck
Figures... I end up with a problem no one apparently has heard of before. Just my kind of luck
Old Jan 20, 2011 | 03:36 PM
Farmboy 2.0's Avatar
Not to sound blunt but have you called any tranny shops about it?
Old Jan 20, 2011 | 04:53 PM
cummin_un_glued's Avatar
FormerVendor
sounds to me like its a valvebody problem...something to do with the lockup solinoid
Old Jan 20, 2011 | 09:17 PM
Default trans
I did call a tranny shop and they told me it sounded like either the converter or the lockup solenoid. I replaced the lockup solenoid and pressure switches and it still does the same thing. The reason I don't think it's the converter, is because it disengages when driving down the road and letting off the throttle like its supposed to. If the converter clutch was "stuck", one would think it would be stuck all the time.
Old Jan 20, 2011 | 10:14 PM
FormerVendor
ok then its sounding like a problem with the valve inside the valvebody that the fluid go's thru when the solenoid tells it to...sounds like it might be sticking open and keeping the convertor locked
Old Jan 21, 2011 | 08:53 AM
Default valve body
Do you know what sensor, or sensors tell the PCM to activate the lockup solenoid? It feels like something is telling it to lockup, at about 5 mph and performs normally at highway speeds.
Old Jan 21, 2011 | 09:05 AM
I agree with cummin un glued. Sounds like the piston in the valvebody is sticking open allowing it to stay locked
Old Jan 21, 2011 | 04:09 PM
Default valve body
ok, I'll check into the valve body further. I appreciate the replies.
Thanks
Scott
Old Jan 21, 2011 | 04:50 PM
Your Welcome
