hard starting @ about 10 above and lower
Old Jan 17, 2011 | 03:09 PM
SnoMan's Avatar
Default hard starting @ about 10 above and lower
Hi Guys, I noticed with my 02 lb7 that it starts hard at about 10 above if it sits all night, last year it started good all the time down to -10 below. It just turnes over and over and over. If I park the truck in the garage at night it is about 20 degrees in there it starts right up. I even put the light weight oil in it this year to see if it would help. When the truck starts it sounds like a old diesel tractor starting on only a couple cylinders then it revs up and smoothens right out. I am going to check balance rates this morning I just checked them a couple months ago and they were fine. I put a new wix fuel filter on it too, no check engine light is on eather... what do you guys think???? Thanks
balance rates are good on the injectors, I am thinking if is somthing with the glowplugs, any ideas where to start? no codes are showing, thanks
Old Jan 17, 2011 | 05:12 PM
DuramaxDiesel02's Avatar
Default Re: hard starting @ about 10 above and lower
Try plugging it in at night and unplug it right before you start it up
Sent from my Droid
Old Jan 18, 2011 | 10:13 AM
veggimaxny's Avatar
Have your batteries checked one is probably weak.
Old Jan 18, 2011 | 12:07 PM
BriteWhiteRam's Avatar
Agreed, its probably a bad battery, if there were anything wrong with your glow plugs or intake heater there would have been a code
try to test the batteries, but if you have to replace one it is better to replace both at the same time
Old Jan 19, 2011 | 08:59 AM
SnoMan's Avatar
Batterys were tested, I found the problem the buss bar that goes to all the glow plugs was broke right after the first glowplug. Had no codes or nothing.
Old Jan 19, 2011 | 10:18 AM
veggimaxny's Avatar
good to know what was wrong
