General Diesel Related Tech Articles For all things that pertain to Diesel.
The Doubler™ Is An All Gear, Dual Transfer Case System
Old Feb 2, 2008 | 06:31 PM
Whit's Avatar
Site Mascot
Default The Doubler™ Is An All Gear, Dual Transfer Case System
Excellent transfer case options here for conversions
http://offroaddesign.com/catalog/doubler.htm
Doubler™ Quick Facts and FAQ answers
Gear reduction of NP203 gearbox: 2.01:1
Gear reduction of NP205: 1.96:1
Gear Ratio of combined transfer cases: 3.94 (basically 4:1)
Overall Length of assembled 203 with NP205: 21.5" from front of 203 to ujoint center
Overall weight of Doubler™ assembled with 203 and 205: approximately 240#
Weight of Doubler™ kit: 24#
The lowest point on the NP203 is about 8.5" below the drivetrain centerline. The NP205 is easily rotated to match.
The NP203 transfer case was used in GM, Ford and Dodge trucks behind these transmissions:
TH350, TH400, SM465
NP435, TF727
C6, NP435
The NP203 gearbox is adaptable to many other transmissions but can use a factory adapter with the above mentioned transmissions.
If you have a Ford front axle (or other application with the differential on the driver side) you need to use a Ford NP205. If you have a GM front axle (or other application with the differential on the passenger side), you need to use a GM NP205. The 203 and 205 do not need to be the same brand, we can mix and match to suit the parts you want to use.
The GM Doubler™ kit requires a 32 spline input NP205 which came in GM trucks with a TH400 transmission from '76 to '84. We have a conversion kit to turn other versions of the NP205 into a 32 spline input.
Ford applications will use any married ford NP205. All Ford married 205's came with a 31 spline female input gear. No modifications to this case are required.
We recommend dual crossmembers for mounting the Doubler system. You can use lightly modified factory crossmembers for many applications or click here for some ideas on custom high clearance mounting.
THW
Mar 17, 2015 08:31 PM
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
steves2500diesel
Oct 14, 2014 05:36 PM
