Dodge Diesel Tech Articles All Years of Cummins Tech Talk
the inside of the getrag
Old Nov 29, 2009 | 11:19 PM
big bad diesel 416's Avatar
Site Sponsor
Default the inside of the getrag
well as some of you i rebuilt my tranny i took a few pics and here is a little advice on rebuilding.........
first read this http://pc-guy.ca/Dodge/Getrag-pdf/GetragG360.pdf
when it is time to remove the counter shaft (page 22-55) tap the shaft as a whole to knock
the rear race out other wise the snap ring will come out hard and you will probably bend it all up if you need new snap rings go here (blumenthals (888) 236-4800) 15.00 plus shipping
when using a press WHERE SAFTY GLASSES AND PAY ATTENTION if you start applying 1 ton or more of force your doing it wrong
when using the bearing puller DONT PULL ON THE OUTSIDE of the GEAR TEETH get full contact with the base
page (22-58) fig 23 MAKE SHURE YOU NOTE THE WAY IT CAME OFF
page (21-63) fig 34 you dont have to heat this just tap it on with a hammer and drift
the 3-4 and 5-reverse syncro assemblies (page 21-67) dont drop them dont move them hell dont even look at them if you pop the ***** and springs out figure about 45min-hour to reassemble use oil soluble white grease to hold ***** springs and detentes then put a large zip-tie just tight enough to hold them in then slide ring over pushing the zip-tie off
use liberal amounts of the white grease when instaling the brass syncro rings other wise they can stick and break
page (21-70) shimming this transmission requires bearing preload read this page then reread this page i used .081 in shims on the countershaft and .040 on the main use a depth gauge to measure a set of calipers works too measure 180* apart and do it twice
bench shift your trans before you put it in just use a screwdriver and if it is hard on the bench it is perfect when you put on the 2 foot shifter
before you put the shifter put in 5 qrts of a good 5-30 synthetic amsoil,redline,royal purple whatever
enjoy
https://www.dieselbombers.com/attach...1&d=1259556061
pic one front bearing ans 3-4 syncro assembly
pic two 1-2 syncro assembly and thrust washer
https://www.dieselbombers.com/attach...1&d=1259556179
pic three first and revers gear
pic four 5th-reverse syncro assembly and 5th gear
https://www.dieselbombers.com/attach...1&d=1259556445
pic six and seven are the front seal when instaling it onto the shaft grease it other wise you will roll the edge as shown
pic five fith gear spacers and VSS internal gear
Attached Thumbnails the inside of the getrag-102_0503.jpg   the inside of the getrag-102_0504.jpg   the inside of the getrag-102_0505.jpg   the inside of the getrag-102_0506.jpg   the inside of the getrag-102_0507.jpg
Brendancory1992
Aug 12, 2015 11:16 AM
Oct 30, 2014 08:10 AM
wvwelder89
Sep 28, 2014 02:23 AM
