propane yes... or no?
Old Jan 10, 2011 | 11:05 PM
Rollins284's Avatar
Default propane yes... or no?
i've got and 02 with 260135 original miles just broke in right??? i'm running an edge comp box, fass 150, hypertech max energy, 4" exhaust and a cold air and i'm only getting 14.4 mpg when i baby it max speed of 65 and no hot roddin in between i'm guessing i need to replace the injectors yes but i was also talkin to a guy that told me he had propane on his 18000 lb mechanic truck and was gettin 25 mpg should i?
Old Jan 11, 2011 | 10:41 AM
DanLowe's Avatar
Just remember, that 25 mpg's is great, but you're filling up two fuel tanks and have two fuel systems now.
Old Jan 11, 2011 | 10:45 AM
Whit's Avatar
Site Mascot
its hard on the rings................JMHO
DanLowe's Avatar
Heres the other thing, fill out your sig the rest of the way, model of truck, tire size, that sort of thing, and we can help more. If you've got 37's and an 8" lift, thats the right mileage. If you're stock height and 265's, theres a problem. Also, what gears are you running? A lot of guys have 3.55's in the dana 70 and 3.54's in the 80. Some also came with 4.11's. All of this goes into account for fuel mileage. One sure fire way to increase mileage is to make sure your tires are aired up to manufactures specifications.
Old Jan 11, 2011 | 11:12 AM
wishlist's Avatar
There is a guy around me here locally and he has propane set-up on his 3500 4dr Common Rail. He claims it does increase his mileage. He also has a Smarty on the truck, which he runs without propane. From what I got out of it, the two are useless together. The cost of the propane set-up entirely would be a healthy chunk to justify for only driving 10,000-15,000 miles a year. I don't know how much driving you do in your truck, but if its in that range or not far off I would look into other means. Such as economizer injectors and a box with a fuel economy tune.
Let me know if you find anything else on the propane or any good deals, Interesting topic
Old Jan 11, 2011 | 11:38 AM
stodg73's Avatar
I have propane and a SMARTY, I run both and have run the SMARTY on different levels. It is a pain to have 2 different fuels, yet I get about 20 mpg at 75 without propane, and when it kicks in it help to pull the hills. My system was about $500 for me to install it, kit, hoses, and D.O.T. approved tank. I also have the propane set to turn on at about 2 psi of boost. The most improvement in MPG comes from the right foot.
When I did mine, I figured that I needed to use it for 10,000 miles with diesel above $3.00 per gallon. If diesel went below this, then it wasn't cost effective.
Here are some links for propane discussions:
Propane Injection
Propane Discussion
1997silverado
Sep 11, 2015 11:27 PM
May 5, 2015 08:50 AM
