98 dodge won't start
Old Jan 9, 2011 | 09:18 PM
370fire's Avatar
Default 98 dodge won't start
i have a 98 dodge 12valve that won't start with the key, and when this happened the windows will not roll up or down and the door locks will not work either. you can push state it but when you want to start it with the key everything acts likes it wants to start but i will not engage the starter
Old Jan 9, 2011 | 09:34 PM
Whit's Avatar
Site Mascot
sounds like you need new starter contacts.......................check em out here
Larry B's
LarryB's Dodge starting problems solved here.
Old Jan 10, 2011 | 01:26 PM
370fire's Avatar
Thanks but before it did this when it would do this before you could wiggle the key and it would start it acts like a relay or its a short maybe i was wondering if there was a way to by pass the key switch to make sure the starter is ok
still need help anybody else have any ideas why it won't start with the key
Old Jan 10, 2011 | 01:37 PM
Ive never done it or even had the column open but I would guess that you should be able to jumper the switch...like hot-wiring it.
You will likely need a wiring diagram.
Old Jan 10, 2011 | 07:22 PM
370fire's Avatar
Thanks do you know where i could get a wiring diagram for it
Mac1997
Jul 13, 2015 05:08 AM
PeteBug
5.9L 24V Performance
May 23, 2015 01:17 PM
rschriek
Jan 26, 2015 07:30 AM
mtvivan
11
Jan 22, 2015 06:14 PM
elkmaniac
Oct 29, 2014 07:01 PM
