stroker no start, help me please
hey guys, my bud has got with the times and got one of these powerstrokes, it has not run in 3 weeks, the gp controller is going out so we jumped them manually, no start, pulled top off fuel filter bowl turned key level rises, does not fire al all
, had block heater, pan heater, as well as herman nelson under it today, refuses to fire, no smoke out pipe, so id say no fuel making its way into chambers, i do not know a great deal about these psds as im a idi guy any help much appreciated
Thanks in advance
, had block heater, pan heater, as well as herman nelson under it today, refuses to fire, no smoke out pipe, so id say no fuel making its way into chambers, i do not know a great deal about these psds as im a idi guy any help much appreciatedThanks in advance
With my little knowledge of powerstrokes all I can say is start with the obvious. The powerstroke uses high pressure oil to operate the injectors, check you oil level. I know it sounds odd but one of the medic units had a no start issue and it was due to low oil from an oil leak.
I'm sure someone with WAY more knowledge will come give yuo better advice soon...
My 96 is doing the same exact thing acted like it was running out of fuel about a week ago and died. I refilled it and tried to start it for about 6 hours in the past week fuel bowl is filling, but no starting or smoke coming out of the exhaust. If I learn somet
hing i'll let you know.
gonna put a cps in it today, cody 7.3 ill let you know how we make out
installed a cps still no fuel makin it into to cylinders, any other ideas onyone? im stumped with all this electronic stuff
Last edited by agent_123_2000; Jan 9, 2011 at 07:59 PM. Reason: Automerged Doublepost
Check the fuel bowl heater, it's under the fuel filter if that's bad it will short out the 30 amp maci fuse in the engine compartment. So check those.
Also when you pull the fuel filter out check the port going to the fuel pressure regulator, the thing with the bike stem valve on the drivers side, there's a screen that goes from that to the biel that always builds up with crud
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
