Turbo Upgrade
Old Jan 7, 2011 | 12:55 PM
CoalTrain99's Avatar
Default Turbo Upgrade
I got a buddy looking to upgrade to a better turbo mostly for towing and maybe a little light to light in town..Whats the best drop in replacement to go with?
Old Jan 7, 2011 | 08:43 PM
Default Re: Turbo Upgrade
Super B or Phat Shaft 62
Luke
Old Jan 7, 2011 | 09:52 PM
kingbrad89's Avatar
I've heard very good things about the bd super b single. I'm a big fan of bd, I have the super b special on my 01 and love it. But... I would never recommend it to anybody that tows a lot. I would say go with the regular super b in my opinion. If I could go back and buy a turbo over again I think that's what I would have bought over my special. The truck hauls a** but a 64 sucks to tow with. Otherwise its killer. Stay with a 62 or smaller for a daily driver/ tow rig. Unless of course it gets compounded!
Old Jan 7, 2011 | 10:03 PM
Ya 64/71/14 can be lagy when towing even on the Common Rail.
Luke
Old Jan 8, 2011 | 08:46 PM
blowin smoke 1's Avatar
My super b special won't go over 1300 but, I have not towed with it yet,it lights great with 100hp vp and 50hp inj and quad v2 with 3000 tune now my dtt trans slips to second gear 6300$ trans you think it would hold it callin them on monday.I love the special I got from Diesel Dogs you can always grow into a 64!I have a super b layin around
Old Jan 8, 2011 | 10:22 PM
kingbrad89's Avatar
I'm curious to why mine runs so hot then. Prob being that I run a bigger injector for spool time. I'd be curious to drive your truck and compare man. Thank god my trans is still holding... I baby it tho. Other than the now and then light to light or highway overdrive romp. Mine tows hot for the most part when I'm underspooled obviously, if I turn overdrive off and slow it down but run higher rpm it runs in the 900's up any hill. But otherwise I can hit 1600 towing very easily.
Old Jan 9, 2011 | 08:49 AM
1slow24's Avatar
so i did catch you have a turbo just laying around and it is not a special correct?
Old Jan 9, 2011 | 10:01 PM
jake 94's Avatar
My 64 is lagy on the bottom but when that thing lights o baby look out and I usually don't see over 1300 even with 60 psi of boost
Old Jan 10, 2011 | 07:23 PM
Turbolvr's Avatar
The aforementioned turbos are S300 based and need a new downpipe to go with them. They will also NOT work with a turbo mounted exhaust brake (if you have one).
The only true drop-in is an HX35/40 hybrid. it is only a mild upgrade. if you plan to push over 400hp, an S300 variant or compounds is needed.
Old Jan 10, 2011 | 07:25 PM
kingbrad89's Avatar
I second that. My 35's broke loose on me one day when I punched it at 70mph on the interstate. Dry pavement too. I had to check my pants. Wonder what my options are for compounds using the super b special... Anyone??
