Dana 60
Old Jan 4, 2011 | 08:57 PM
snowman88's Avatar
Default Dana 60
Not quite sure if this is the right place or not but here goes:
I can get my hands on a cheap Dana 60 full floating rear axle, but the problem is that it is only a single rear, not a dually like i want. Can i get hub extender/extensions for it? Does anyone make them, or do i need to just find a set in a junk yard to swap onto it?
Thanks
Old Jan 7, 2011 | 10:10 AM
HAAS's Avatar
IMHO I would find a 10.25 or 10.5 Sterling out of a newer Ford due to the strength vs. the 60. A Dana 60 rear axle is only about the size of a 9" Ford. The Sterling rear is close to the size of a Dana 80 other than the ring and pinion. Also there isn't a difference between the single or the dual wheel housing. They use the long wheel studs to be used on either.
Old Jan 7, 2011 | 11:54 AM
u2slow's Avatar
I would also skip the Dana 60 for running duals. Its cheaper to buy the right rear end than adding wheel adapters.
A few better axles, in no particular order:
- 14 bolt full-float
- Dana 70
- Dana 80
- Ford 10.25
Old Jan 7, 2011 | 05:01 PM
snowman88's Avatar
Thats kinda what i expected, but was hoping it wasn't the case since this axle is gonna be super cheap. I guess i'll just find a dually chassis to swap the cab onto.
woodsman27
May 23, 2015 10:16 AM
tractormandan
Wanted To Buy (WTB) - Used
May 9, 2015 08:44 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
KYLEBOY
Jan 18, 2015 06:36 PM
gyayo2012
Nov 15, 2014 08:11 PM
