2002 Duramax White smoke Help!!
Old Dec 29, 2010 | 11:48 PM
duramax02's Avatar
Default 2002 Duramax White smoke Help!!
OK I Have an 02 LB7 Duramax it white smoke at idle.. My severe engine light came on for glow plugs could that make it white smoke??
Old Dec 30, 2010 | 09:01 AM
02LB7DURAMAX's Avatar
It's probably your injectors.
Old Dec 30, 2010 | 09:42 AM
Smoke 'em's Avatar
My buddy had an 02 that would idle a little white smoke then blow out a nice puff when he took off... Injectors
Old Dec 30, 2010 | 01:54 PM
BriteWhiteRam's Avatar
agreed, get your injector balance rates checked out
Old Jan 2, 2011 | 07:51 PM
duramax02's Avatar
when i drive no white smoke its black??
Old Jan 2, 2011 | 08:43 PM
Smoke 'em's Avatar
You have a programmer or any other mods that would make it smoke black? My friends was bone stock so no black smoke, just white
Old Jan 5, 2011 | 01:54 PM
duramax02's Avatar
nothing its all stock i've had two duramaxs and they smoke black i'm going to have it checked out
Old Jan 6, 2011 | 07:17 PM
Back-in-Black's Avatar
mine did what your is doing when my 3rd set of injectors went out. White smoke at idle and grey/black when running down the road. Installed 8 new ones and that fixed that.
I'm on my 4th set of injectors (including the factory set) and just about every time they went out, it did something a little different.
1st time it filled my oil pan with diesel and the oil pressure gauge was reading 0.
2nd time very little smoke but my mpg's dropped about 4-5 mpg.
3rd time I looked like a train smoking at stop lights and going down the road.
Old Jan 7, 2011 | 11:32 PM
brettdfny19's Avatar
i agree... i currently have the same prob with my 03... its my #2 injector causing the problem... white smoke at a idle, but driving down the road nothing unless i get on it then black smoke... but if you are looking for 8 new injectors go to duramaxonly.com mike there has great prices on stock injectors... while you are at it, i would change out your glow plugs too... just to save trouble... im doing the same thing... hope this helps
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
zoomer10h
Feb 6, 2015 01:38 AM
ASarsano
Oct 15, 2014 05:33 AM
