6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
6.5 lifting head
Old Dec 28, 2010 | 09:00 PM
Ac6080's Avatar
Default 6.5 lifting head
I have 93 6.5 in my 1982 k30 and want to make more power, and i know that if i turn the pump up much im gonna start lifting/cracking heads. Is it worth getting arp head studs for it or not. Also i heard that 6.2 heads are better than the heads on a 6.5 and i have a 6.2, should i change the heads or is it not worth what i would gain. Thanks in advanced for any advice.
Old Dec 29, 2010 | 08:45 PM
Woody35's Avatar
Do you have a turbo?
Old Dec 29, 2010 | 11:46 PM
Ac6080's Avatar
ya its a 93 6.5td mechanical pump
Old Dec 30, 2010 | 01:49 AM
Woody35's Avatar
i wouldn't go past 14 psi with stock headbolts. your going to need a boost gauge and pyro before you turn up the fuel. some 6.2 heads have bigger valves but injectors could be different so watch out for that. use 6.5 gaskets though whatever you do.
Old Dec 30, 2010 | 08:40 PM
Ac6080's Avatar
what about with some aftermarket head studs, like some ARP's or somethin.
Old Dec 31, 2010 | 01:14 AM
Woody35's Avatar
if you want to go past 14 then i would get arps. just the turbo we have isnt much good past 15 psi. at that point it is just blowing hot air
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
Apr 14, 2015 09:04 AM
greatlakes diesel
Feb 13, 2015 09:55 PM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
